Well i know that it have to resign to it being a 125VA transformer but still i would like to know about how andrew will work out the Va as i mentionned i have other transformers unmarked which will help me determine the approx VA plus in case i buy new ones it will help me avoid be chosing wrong types.
So andrew the size of the whole limination is 8.6 cm by 4.8 cm from top and height is 7cm
In case this is what you need please explain you derive the VA rating
the E of the EI has three legs. Two narrow legs pass outside the bobbin.
One wide middle leg passes through the bobbin.
The wide leg is approximately double the width of each of the narrow legs.
Measure the width of the wide leg that passes through the bobbin.
Measure the thickness of the stack that passes through the bobbin.
I had the EI transformer programme on my old HDD, but not on my current installation.
Can anyone provide a link to the programme?
For conventional EI transformers the rule of thumb is that bringing to a square the product of these two numbers gives the approximate power rating.
In this case it's (2.8×4.3)^2=145VA
Attention, it's not a proper calculation, it's only a rule of thumb for such cases when rapid help is needed!
Thanks a looooooooooot Andy that's what i was looking for this eill be of immense help to me even though being only a quick and approsimate calculation.
Well just as an info i can get toroids here but the people selling them are unable to tell me the VA rating( they just buy and sell their concern is no more). Its made and imported from china without any brand or marking except the primary and secondary voltage. Is there a similar rule of thumb for the toroid core's?
Thanks Andy but sorry just a little precision is 11cm the internal of external diameter of the ring?
They have 3 models here (hope still in stock) but i'll see if i can drop around and check the dimensions.
They had a huge one had to lift it with both hands approx dia was 15 cm external and 6 to 8 cm high. You think that could be a 1000VA(was coded PVA1000 but i don't trust that)?
I mean external diameter.
They had a huge one had to lift it with both hands approx dia was 15 cm external and 6 to 8 cm high. You think that could be a 1000VA(was coded PVA1000 but i don't trust that).
Yes, 15×6...8cm dimensions for an 1000VA rated toroidal is absolutely realistic!
But before i jump into another problem, each woofer is rated 8ohm 150Wpeak (has vented pole piece) to be used in sealed enclosure with LR4 xover + Linkwitz transform + bridged amp per woofer. Suppose i do go for a 500VA transformer for all 4 amps and that i am able to get 200W per bridged pair won't that damage or simply blow up the woofers in the long run?
With one 125VA per amplifier pair a very rough calc gives me max 87.5W. I know its a very bad way of solving the situation but won't that be safer assuming the sub won't be pushed to distorting volumes?
Previous post was a bad idea another solution i could consider is to go back to step 1 when i initially started the thread i.e use a 30-0-30V 150VA transformer which i have lying around. I would then use one of these amps per woofer and purchase a second one. Still i'll check the toroidal price and keep posted
Fake TIP 36C???????
Got the caps for the amp yesterday am planning on building one unit for testing. Got 4x 10,000uF 63V. Am still thinking of something. Has anyone encountered fake TIP35C/36C around or have any pictures of what the die size should be like. Had one of them as a look yesterday at one supply store the markings on it looked stranged could be relabelled TIPs i'll check at a second store today and keep posted. If need be i'll purchase a pair and crack it open and post the pics
Thanks Nordic, do you know of any in SA that are trustworthy and that might ship to mauritius since we are almost neighbours shipping could be cheaper
Have you ever came to mauritius by the way? Think its a bit known in Sa remember was a huge poster on the street while i was in joburg talking bout it. Well talking bout joburg always reminds me of the lounge in case you happend to know the place
Re: On line parts purchase
I'd try Farnell.
Farnell homepage
Search for TIP35C/36C by STM (ST Microelectronics).
zeus_threat said:Does anyone have a link for a reliable supplier that sells genuine power transistors online shipping worldwide on low amount orders
thanks
I'd try Farnell.
Farnell homepage
Changing output devices
Thanks for the link i'll check it . Well actually i'll try to go for MJ15003 and MJ15004 instead since it comes to almost the same cost. I don't mind modifying the pcb. I'll try to see if i can get my hands on a local MJ15004 by tomorrow or saturday and crack it open. I have two choices here either Mospec or motorola. Mospec is slightly cheaper. Are both likely to be as counterfeited as the other?
thanks
thanks
Fake MJ15004?
HI guys thank for the replies i got my jands on an On smi MJ15004 sold locally cost is around $6 but that does not mean anything. But am intrigued. I cracked one open no double die inside the die pattern looks exactly like the one shown at ESP. Only thing is that i did an acetone test had to rub a lot original marking was
ON
MJ15004
MEXICO
BM0222
After rubbing a cotton bud with acetone this is whats left
MJ1500 (the last zero is quite pale)
MEXICO (the last o is quite pale)
No thick silicon on die but a thin gray paste below the die.
die size 6mmX5mm
Looks like a pnp but opened it then tried measure polarity.Should have done that first
Could this be a fake?
On going ahead to see if i can post a pic of it
ON
MJ15004
MEXICO
BM0222
die size 6mmX5mm
- 100W peak 4Ohm
