Stolen Trademark Amplifier from Jim's Audio on EBAY
At last. Enough for convection cooling. Works well, full bias. Modified with to ekstra output transistors on each half period. Twelve on each channel. Added ekstra driver for each pair. Biased to 0.4 A on each transistor = 2.4 A. The heat transfer to the heatsink improved dramatically with 2mm aluminium oxide insulators plus thermal paste on both sides. The transistors conduct much more evenly. Measure almost the same voltage over each emitter resistor. Way better than the Silpads.
