TDA2030 with transistors
Very interesting. But saw form signal is not the most difficult signal for the amplifier. Try square signal.
I've finaly made my amp. It happend I have different channels. There are KT 818/819 in one channel and TIP 41/42 in another one. But I hear no difference between them. And a heatsink is a little too small, although it is enough for home using.
mjf, what can you say about sound quality? Do you like how your amp plays music?
I have had the same idea.
But here is a line amp using OPA134.
Up to like +/-20mA the op amp delivers the current.
Above this level the transistors will step in with current.
The result is a line amp with lots of driving capacity.
This amp will do well as a headphone amp.
mjf answer: a triangle is a "linear" signal, a straight line, so you can see deviations ("distortions") from it better on the screen ,e.g. a crossover distortion looks like a little shift in the mid of the signal.......
in short: the sound is acceptable for me (if not i would throw it away.....).
i will carry on, tomorrow is a bank holiday here.........
Am I imagining or is there a very slight kink in the curve where the boosters kick in (at 2.7R load) - which should be at around 3,5V. (IIRC you posted that you changed your sensing resistors to 0,5R and that would set the trigger current to somewhere at 1.2-1.4A, which would translate to cca. 3.5V into 2.7R).
mjf, can I see a photo of your PCB? I am interested to see how you made the GND track.
it is only a prototype with an old pcb.........that means: a wire nest.
i will buy a tda2030a and other transistors soon.......
in short: the "- returns" are tied together in a single point.....and from this point a wire goes to the psu -
