100W Ultimate Fidelity Amplifier
Stereo DC and overload protect
apex stereo protect
Here's the .lay file for the stereo protect :)
This one is adapted to an single 15VAC secondary as an PSU,for higher voltages another relay and it's backing resistor value should be changed :D
On the sidenote,I built that FH11 in the post above ;)
  • layout.zip
I redrew it also, for anyone that may want it. I included gerber files and pdf's.
  • Apex Stereo Protect DC.zip
  • DipTrace PCB - Apex Stereo Protect DC.pdf
  • DipTrace PCB - Apex Stereo Protect DC Bott.pdf
  • DipTrace PCB - Apex Stereo Protect DC Bott Flipped.pdf
Apex,
I have simulated the FH11 on LTSpice, trying several bias currents.
That's why I wanted to know the bias you used to get 0.045% THD @ 1KHz, getting 225watts for 8ohm load, and 60v p-p.
For 8ohms it would be impossible to get 225 watts with a +/-60v supply. What I get at 8ohms is 142 watts for 1KHz, and 0.004% THD. That is at pre-clipping levels.
Not superb, compared with a Honeybadger, for instance, but decent.
What I found is that output could be improved if the LTP THD is improved. In most designs I have simulated, the LTP was very good until it went through the VAS.
Which of your LTP inputs has lower THD?
