CFH7 Amp
Joined 2014
I never said they are genuine but they work. Also, some humble workhorse actives aren't going to be faked. BC547/557, BC550/560, J110, J310, 2SC1845 etc. I measure my caps with LCR meter and they are within spec. Always on the low end so 2200uF is really 2000uF.
What's the point of wasting time and efforts on building amps with inferior
parts? Price wise, it's cheaper to buy them from Best Buy.
It's about building amps that are better than that, and this can't be done
with fake parts from Aliexpress...
Founder of XSA-Labs
Joined 2012
Not going to argue about this. Just letting people know there are options. I have about a dozen amps that would tell you otherwise about how good Chinese sourced parts can sound. Many components actually originate from China (according to my genuine parts compliance statement from Digikey) so doesn't surprise me.
You can look at my amps (more than a dozen and counting) and even listen to them - most made with AliExpress sourced parts. Some parts I got from Digikey, but I found no difference in sound quality. And I am quite certain they sound much much better than any amp from BestBuy :)
http://www.diyaudio.com/forums/solid-state/295286-virtual-audition-very-simple-quasi-mosfet-amp.html
580661d1479476675-virtual-audition-very-simple-quasi-mosfet-amp-ss-amps-2016-review2.jpg
Here is the Aksa/Ranchu quasi amp in Dacz layout. A beautiful sounding amp and 100% AliExpress sourced (except for heatsink (Dell Pentium CPU cooler and PCB from PCBway.com, also in China).
CFH9
Now i can't believe that is something to do with oscillations .
100nf parallel to 2200uf removed.
Capacitors parallel to feedback electrolytics removed.
One pair of output fets removed.
A separate 100uf//47nf for each fet installed directly on fet pin.
Zobel removed.
Rails has been traced again,using analog and digital scope.
32 KHz square wave 15v RMS ,i cant see something wrong:confused:
Then putting the scope between power GND on board and signal GND...clear visible sinusoidal.Exactly what the input signal is but at a lower level.It is 15mV when output is 2V.
Pictures,1,2,3 32KHz
>> 4,5 The rails
>> 6.7 The rails
Picture 8, 15V RMS 32KHz
Picture 9 The probe between POWER GND & SIGNAL GND on the board.
Zobel removed.
>> 4,5 The rails
>> 6.7 The rails
Congrats! It's clean. :up:
But if you are shorting the 10R lift resistor then the sinusoidal shouldn't be there. There should be 0V if the signal ground header is connected to ground.
Zobel removed.
>> 4,5 The rails
>> 6.7 The rails
Only after you have debugged problem I remember.
Borys made good suggestion, how to lift input gnd on CFA amps in 100W Ultimate Fidelity Amplifier thread.
