The Pass Pub: The High-End Off Topic Thread
Official Court Jester
Joined 2003
one of these
though , I tend to prefer System 15 , at least for HF part
Joined 2003
Thanks a bunch Massa. Btw didnt find OB build thread, only WAF. Shall I not go for wider baffle ideally? Those for series bass helper chokys?
ya sillybikelovingsuede
of course ya can use wider baffle
obviously you didn't read , just looked at porn ..... I wrote dims of me baffles are determined by space available , then accomodation resulting in sort of H frame (or hybrid between U and H ) function
I hope you didn't in same situation , having space for at least 70cm wide baffles
Some other sweeties I stumbled over
ook ya , me hate
Edit: Now found "older posts-buton", looking at OB-filter semi finished. Evolved?
yes and no , irrelevant
what's relevant for ya is - find proper choke in range of 6-9mH and put in series with bass helper , irrelevant what type of enclosure for it you're going to use
Torobar is having good ones , 8.2mH , tried and blessed in my Sonido speakers construction
very good price/value ratio
Joined 2003
well , https://youtu.be/A4I9DMSvJxg ....
of entire xover , made for my Absolute WAF Tann OB , you can use just bass helper part
as you can see - my Tanns are Pepperpot ones , while yours are Tulip equipped ones , so HF part of xover is mucho different
yes , go for System 15 xover as start , later you can fine tune what's needed - most probably just value of series attenuation of squawker and , depending what solution you choose for bass helper , maybe some series resistance for bass helper driver
if nothing else , when you have some time , measure at least Fs of Tann drivers ..... just to have that on file
edit : and yes , porn is mandatory
Your letting you musical taste show. I was driving with one of my daughters at about the age of five years when war pigs played on the radio. To my surprise at the siren call at the start the kid exclaims "yes...War Pigs...make it rock and roll...". Make it rock and roll means make it loud enough to **** off Mom.
https://m.youtube.com/?#/watch?v=K3b6SGoN6dA
