what do the settings in the "power" settings do?
does adjusting them give any subjectively better "audiophile" sound?
No.
Are there any settings we can adjust to give subjectively "better" sound?
Tone controls?
Hi guys.
I can not get sound from the Daphile. Everythink was normall
Post pics of your Daphile settings & also the hardware used.
Ideally, you show the network settings?
I also seem wi- fi disabled
I'm sorry I can't help you, without pics of Daphile settings & the hw used it's not possible help you.
Hello
Is there any way to get daphile to play ts audio files. I record bbc radio3 on a humax foxsat hdr and it gives out ts files but daphile doesnt recognise them.
Or what should I convert them to, losslessly if at all possible.
thyristor44
Have you used Foobar2000 converter? It's easy just push right button of mouser and appears the window.
Is it possible to set the Memory play as a standaard? So always memory play is used...
The latest dec 8th version has this capability, but... the new version of Daphile with pcm last night and media server crashed a few times requiring a complete reboot once. Previous version never crashed.
Version dated Dec 8th.
Not yet. If more tracks are added to a playlist, the RAM button needs to "pushed" again. To work properly, Daphile would need to load and unload tracks from memory as the playlist progresses. For a large playlist, it will not be possible to keep everything in memory.Is it possible to set the Memory play as a standaard? So always memory play is used...
Is there any way I could record what I am streaming on Daphile, either by a modification or by using a different player that will record.
Do you mean record the digital stream?
Yes I would like to record the stream from mainly the radio stations, so a player that could do this would be usefull.Do you mean record the digital stream?
- PC Based
- Daphile - Audiophile Music Server & Player OS
