Resistor Sound Quality?
<snip>
My take is that the listening tests with null results are not failures, they are simply reliable evidence.<snip>
That seems to be a plausible conclusion and is a valid hypothesis.
If appropriate positive controls were used, it would have been possible to find some confirmation of this hypothesis.
Without positive controls (and usually negative controls) it is nearly impossible to show that your conclusion is justified.
My apologies, to the Forum and to Max...
Graciously accepted and acknowledged Sir :up:.
Why don't you tease us with anecdotes about your magical BQP equivalent....
In time concrete/reproducible data will come...
I treated the FOH production power/FOH audio multicore on a stadium system tonight The_Amity_Affliction.
Fellow crew member and I described the substantial and not so subtle sonic change/improvement in same words.
The change in bass/low bass is physically palpable...and most agreeable.
Much better clarity in vocals...limiting/processing clearly revealed.
Highs clear with splash and hardness removed....enjoyable.
Reduction in RFI may be part of the the cause, but I think not the whole story.
At least I keep my sycophantic urges under control
Please do not misunderstand me....I do not idolise JC, BUT I do respect his achievements, and I do enjoy reading/learning of/from his experiences and knowledge, just as I learn from the valuable snippets that you drop re layout, EMC and other subjects.
Regards, Dan.
Can you cite some examples of those positive controls?
Ok, Marce, show us your ........ audio designs.
I don't have anything particularly notable to report on the design side, but I am interested to hear of your audio triumphs.
Go ahead, tell us about your listening gear, and what you have constructed.
I am sick of seeing always the same people following JC's posts, no matter in which thread, and effectively derailing it and destroying any exchange of information.
I have to agree, and it is the same parties reflex arguing against observations that they/nobody fully understands....more discussion and teasing out of facts would be much more productive.
JC for one, has vast design and T&M experience going back to before most of us were born....I for one would like to learn more from his recollections, but alas John rarely gets the chance to get a word in edgeways.
If I want to be reminded of electronics 101, I can always read a book....
We are all past EE 101,.....Marce, your insights into fine points of PCB design are appreciated.
Dan.
Regards, Dan.
As I have said I have a lot of respect for JC and have crossed words with him many times regarding the more esoteric beliefs....
He has in the past. Generally, he likes to pull out variables that are different than the ones being actually tested (e.g., level), which don't really have validity.
Positive controls are important where appropriate, but they aren't always appropriate. Inflexibility in experimental design is a sure path to failure.
It is a waste of time to follow this thread but often I act stupid.
To keep up with what's going on: when talking about "JC" who is meant? John Curl?
Jebediah Cuthbertson. He invented the Cuthbertson Frammistat about 40 years ago, and has been living off that ever since. It was, to be fair, the first bilateral frammistat, though some might claim that it was too obvious for patenting, given the long and rich previous history of frammistats. Nonetheless, he's been flogging it ever since and seems to have a small group of fans.
It shows the definition of terms. It shows no examples of positive control
in audio electronic component listening test.
For example, if you want to test whether a DUT component extends the highs
compared to the reference component, you would try a third component known
to extend the highs, and see if that's what you perceive. If you can't perceive that,
there's no point in doing the test. Maybe there's not enough bandwidth in the source,
or the extended highs do exist, but are not recognized through inexperience or
hearing damage, etc.
You must not be familiar with audio DBT. Before the start, those components with the claims of audible difference are compared in non-DBT just to see if the listeners agree. If they do, then DBT proceeds. If they don't agree, no DBT.
Not everyone can hear well, or has enough experience or ability, to give a reliable opinion.
What matters is whether a particular individual who DOES, can hear differences.
If you're sick, you don't take a survey of random people, you go to a good doctor
who specializes in your problem, knows what they are doing, and who is much more likely
to have a valid opinion than some yutz.
The conductor of our local symphony didn't notice that our then-new concert hall had poor,
weak bass until I pointed it out to him.
