100W Ultimate Fidelity Amplifier
Bimo's De Luxe version of AX11
I changed the values of few components. PCB design is original Anistardi's. This is the best version of AX11. Highly recommended!
Connect input gnd to psu gnd...
Thanks Sir for replying. Now it is give around 20mV
But there is a sound problem it cannot play anything clear i also tried adjusting the bias still the same
please what could be the problem please see image?
My AX-14 update:
Just checked again everything works fine for the low frequency but for high frequency is sounding so slow.
please tell me what to change i want to use this amp for high frequency.
Congratulation. :cool:
Can you share the components that you changed?
How about sound impression?[/QUOTE
I slightly lowered the current through VAS transistors (R12, R16), using 68R instead of 47R.
R1 = 750R
C2 = 220pF
R22, R23 = 0R33
I am short of time at the moment so I shall share subjective impressions later.:)
Thanks Mr. Evanlukic,
I am going to test this Bimo version too. I made my own layout posted in http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-541.html#post4460302. I will update it with your tested values.
Reg
Prasi
Yes, it's stereo.
Schematic from mister Mile http://www.diyaudio.com/forums/soli...imate-fidelity-amplifier-550.html#post4518802
Sprint layout file for own customizations attached
Oh, i see now i skipped 100K resistor from 5551 colector to +, sorry about that
I etched a couple boards per your sprint file. After completing them I decided to add some text to note the use of the terminals for clarity later. Alignment is not perfect because I added it after the fact. I also added a little copper at the ground trace at the bottom. It was very thin where it passed the "Pro" connection. I will try to populate them today if I have time.
Blessings, Terry
Sorry, the post is #5402 (my layout). Bimo's updated schematic (on which my layout is based) is at #5221. Bimo's original layout is at #5214:D
reg
Prasi
Thanks.
After etching I noticed a missing resistor. I added it to the sprint file and will just fit it in on the pcb I already etched. Let me know if I am right about this.
Thanks, Terry
