100W Ultimate Fidelity Amplifier
Pins 2 & 6 are the -IN pins.
Pin2 has R16 and R19 connected. These should be on very short traces to -IN.
Pin6 is unused.
Connect this channel to sit at half way between supplies.
I'm not sure about C3 & R7, maybe someone else can advise.
But C3 should maybe swapped with R7, so that the resistor is next to -IN.
it is my favorite hobby of all
If it is so,make a pcb for this amplifier protection:)
Here is a quick idea for layout of the protection PCB. It can be improved further based on suggestion of Mr. Mile or someone else:D. Meanwhile I will keep on making it pretty;).
reg
prasi.
