Aleph J Schematic
Hello Papa
Refering to your Aleph J schematic, R27 is connected directly to the gate of Q5 and Q6.
Is it possible that R27 is intended to be connected between the junction of R25, R26 and C2? If connected this way it results in 2A bias and seems to operate somewhat better into low impedance loads (from memory).
The way you have it connected results in approximately 2.6A of static bias (a little high).
I know the issue of high bias was addressed by members with trimpots, but it was applied somewhat differently.
It seems to me R27 should have been connected between R25, R26, and C2
I was meant to ask this question approximately 8 years ago. Back then I was a scaredy cat. :D
I have built some 2 terminal ccs's to bias the ltp of my each j.
I am using r8 in series with the ccs, from positive first I have r8 then the ccs.
I have instaled the ccs in one channel, set it up for 14 ma bias for the ltp and is all working up and biasing correctly.
Does r8 position(first or after ccs) and value matter?
Having 14v drop acros r8 I am considering to lower its value to 500ohm. Is this recommended?
