100W Ultimate Fidelity Amplifier
Why not a Circlotron ?
http://www.diyaudio.com/forums/atta...0949d1440743480-vssa-circlotron-opacirclo.asc
Hi Mister Mile! I finished your (mine) AX20 with 555 protect. I took a lot of time, but I did it finally... and sounds good, thanks for your support.
Pozdrav
Greetings,
Just a short question: How do you open the .asc files. ????
Tried to save in pdf and could not open.
Thanks for the help,
Myles
It is much like a .TXT file.
If you rename it to .TXT, WordPad, for instance, will open it (see attachment).
And it will look like this (parts removed):
Version 4
SHEET 1 1844 1344
WIRE -1136 -368 -1264 -368
WIRE -1008 -368 -1136 -368
FLAG -1856 960 0
FLAG 576 336 0
DATAFLAG -608 48 ""
DATAFLAG -912 1024 ""
SYMBOL npn -80 -128 R0
SYMATTR InstName Q1
SYMATTR Value BD139c
SYMBOL pnp -80 672 M180
SYMATTR InstName Q2
SYMATTR Value BD140c
SYMBOL voltage 480 -160 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
SYMATTR InstName R3
SYMATTR Value 1k
SYMBOL res -784 448 R180
TEXT -1816 -120 Left 2 !;ac oct 10 10 20000000\n.options plotwinsize=0\n.options numdgt=8\n.param freq 1k\n.param num_fft_pts 4096\n.param timestep {1/{{freq} * {num_fft_pts}}}\n.four {freq} 19 8 V(Vout)\n.tran 0 {15/freq} {2/freq} {timestep}
TEXT -1800 -296 Left 7 ;Apex A4
TEXT -1800 -168 Left 2 !.include Cordell Models.txt
Obviously this code is useless without the appropriate software (as pointed above by @gabor). :cool:
  • Apex A4.txt
  • Apex A4.asc
