100W Ultimate Fidelity Amplifier
The basic concept coming from mc2 audio. See attached file...
Sajti
Yes, mc2 use same topology... and peavey use similar topology floating supply for OP amp to drive OS directly without VAS.
AX2 use same topology as peavey.
Terry, it was done as mrmax063 suggested using "Alternate" spice solver. Using original values it oscillate once in the beginning.
But look at UltimateX86 file it works perfect using"normal" spice solver.
Sonal Kunal
Here is Mile's latest file. It is actually A2 now.
It runs OK but .2 THD
  • Apex A2.asc
  • Cordell Models.txt
The latest file from Mile sims the best but when tried the changes on my board it oscillates. If I bypass the diodes I can get it to play a sine wave as long as I don't give too much input voltage but of course there is a bad crossover notch. Once I increase the input voltage it starts oscillating again.
Some compensation caps add...
Worse. With C3 installed, instant oscillation. I removed C3 and we are back to where we started. C15 doesn't change a thing from what I can see.
What opamp u using? If compensation not help, maybe opamp is overloaded, add resistor r20 1k.
I'm using TL071. It is the only single channel IC I have.
I will try the 1k resistor.
