Use this script to set them to defined state - turn off. https://github.com/miero/botic-tools/blob/master/hermes-gpiocfg
Wow, this is amazing. Never thought I could control on/off of these LEDs. When feeling lonesome, just one LED lit will be enough; when not, I can enjoy watching the green light of all LEDs lit .
Thanks for this script, which led me to this URL as a homework this weekend.
Thank you miero, for that information. That solves the mystery of the LEDs.
So, did you check the value of unlit LED? If your setup is correct,
Code:
cat /sys/class/gpio/gpio[number of your unlit LED]/value
Code:
0
Well they were all the same ones as supplied by Brian. Yes, it works (tested with DMM) and is in the same orientation as the others.
hi miero,
i am a very linux beginner and trying to mount my music lib ( usb hard drive, ntfs partition) at the location /data/local using the command:
sudo mount -t ntfs-3g /dev/sda1 /data/local
but get bad option notes ! is the ntfs-3g driver not included into the botic5? or how should i mount the ntfs hard drive?
best regards
best regards
hi miero,
best regards
don't worry, i installed now the ntfs-3g
Simple shell script for basic configuration of ES9018 via I2C:
https://github.com/miero/botic-tools/blob/master/daccfg_es9018
Helper for Botic V5 driver to control volume and set HW params:
https://github.com/miero/botic-tools/blob/master/botic_helper
Hi miero,
do I just type these in at the command prompt, or do I have to type them in e.g. nano and save them as something?
I assume the latter and I just save them as daccfg_es9018 and botic_helper? Do Ihave to save them somewhere specific?
Do I have to type
Code:
echo "/sbin/botic_helper" > /sys/module/snd_soc_botic/parameters/helper_cmd
Sorry if these seem obvious, but I'm not a coder (you may have guessed!).
I tried enabling the HW volume control in mpd.conf, but mpc status says "volume:n/a" and when I try to alter the volume in ympd, it says "problems setting volume"
should beCode:cat /sys/class/gpio/gpio[number of your unlit LED]/value
Code:0
I got
Code:
cat:/sys/class/gpio/gpio3/value: No such file or directory
I gotCode:cat:/sys/class/gpio/gpio3/value: No such file or directory
Your gpio number is not correct. It should be either gpio30 or gpio31 or gpio60. Please refer to the original script by miero.
My guess is that you first have to export the GPIO pins used for the LEDs.I gotCode:cat:/sys/class/gpio/gpio3/value: No such file or directory
Something like:
Code:
echo 31 | sudo tee /sys/class/gpio/export
echo out | sudo tee /sys/class/gpio/gpio31/direction
Code:
cat /sys/class/gpio31/value
Something like:
After that you can check their value:Code:echo 31 | sudo tee /sys/class/gpio/export echo out | sudo tee /sys/class/gpio/gpio31/direction
Code:cat /sys/class/gpio31/value
Exactly.
Here are the shell scripts based on the miero's original to turn on/off LEDs.
Turning on LEDs:
Code:
#!/bin/sh
### GPIO pin setup for LEDs on
### LED1 ###
echo 30 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio30/direction
echo 1 > /sys/class/gpio/gpio30/value
### LED2 ###
echo 60 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio60/direction
echo 1 > /sys/class/gpio/gpio60/value
### LED3 ###
echo 31 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio31/direction
echo 1 > /sys/class/gpio/gpio31/value
Code:
#!/bin/sh
### GPIO pin setup for LEDs off
### LED1 ###
echo 0 > /sys/class/gpio/gpio30/value
### LED2 ###
echo 0 > /sys/class/gpio/gpio60/value
### LED3 ###
echo 0 > /sys/class/gpio/gpio31/value
Thanks guys, but I'm not sure how to install (?) scripts.
Save each script as a file using nano or vi, say ledon and ledoff.
After that make them executable.
Code:
chmod u+x ledon
chmod u+x ledoff
Code:
./ledon (+ return key)
or
./ledoff (+ return key)
Something like:
Thanks lintweaker.
I entered the above code and got:
Code:
cat: /sys/class/gpio31/value: No such file or directory
The ledon and ledoff scripts worked though (apart from LED3 not lighting of course).
I tried the same with the daccfg_es9018 script. Saved it, made it executable and executed it, Got this:
Code:
Error: Read failed.
Not having much luck there and volume is still n/a. Am I the only person trying to control the BuffaloII via i2c?
With these scripts, all LEDs should be turned on or turned off. As pointed out by Russ in the other thread, it may suggest the possibility of incomplete soldering somewhere on the Hermes-BBB board, I guess.
I'm beginning to think that's the issue. Odd though, because the joints all look very good (all lovely and shiny).
Oh well, third time soldering them will (hopefully) be lucky!
Not sure why the volume doesn't work though. The Hermes i2c header is connected to the BuffaloII headers and I've added the lines to mpd.conf.
If it is any consolation, Duffy, I see the same behavior. My LED3 normally stays off, and is untouched by these scripts even though I have seen it lit during incomplete BBB initialization. I am messing with ALSA , so not worried about GPIO at the moment. I'll be noting your progress with I2C.With these scripts, all LEDs should be turned on or turned off. As pointed out by Russ in the other thread, it may suggest the possibility of incomplete soldering somewhere on the Hermes-BBB board, I guess.
Frank
Frank
I'm not sure whether this comment can be correct or wrong, but so far, I have built three sets of Hermes-BBB/Cronus boards, each with Botic5 system and all functioning well, and have never experienced such an unlit LED remaining after successful booting.
This may be a particular case only pertinent to the way I set up. But from this experience, I thought and am still thinking that the presence of unlit LED without explicit setting of GPIO value appears a sign of something physically incomplete still residing in your soldered boards.
As far as I know, only the battery setup - actual battery plus 4 pin connection between Hermes and BBB - remains to be installed. I don't want to commit those parts to one particular board until necessary...
- More Vendors...
- Twisted Pear
- Support for Botic Linux driver
