100W Ultimate Fidelity Amplifier
Hi Mr Mile,
Sorry for asking again,
how max Voltage supply for AX20, for +-90v any part modify?
and recommended type of final transistors?
thanks for best answer Mr,
BR//
PDF for ironing Sir.
Hello sir here are the files also the reference schematics I use, I did some changes on the layout for my self but you can use the schematic and change some values of the AX-20P to be the original values from AX-20P schematic, I spend a couple of day already checking for error or better say "bugs" and I have not found any more so far, if you guys see any error let me know so I can fix it right away I said this because eyes get tired man :p
ok here are the files :)
Juan
  • AX-20P v1.5 components.pdf
  • AX-20P v1.5 iron.pdf
