Reproducing a 16Hz pipe organ note
Founder of XSA-Labs
Joined 2012
Freddi,
If you are happy with solid 25 Hz extension, you can achieve this using a single Faital Pro 18XL1600 driver in a K15 scaled up to about a 48 in tall x 20 in wide x 24 in deep cabinet, driven by about 600 watts. Stack 4 of these together and you can get 126 dB at 25 Hz and have the clean dynamics and punch that a Karlson is known for. Here is the response from one box (with K-aperture top slit going to a cusp and starting 5.3 inches from the top) with 23 Hz HPF and 80 Hz LPF (48 dB/oct) applied. Interesting result that a Karlson bandpass box can serve as a sub woofer.
X
Hi Old Ears,
Happy that got you a step forward. Next - after you get the combined SPL - click on Filter Wizard under Tools, that'll open up the Filter Wizard: for the bottom right window pick Active, for the middle pick Bandpass, and for the left pick Displacement. Now you can set the lower displacement peak to be the same or smaller than the upper one by adjusting the Lower Cutoff Hz in the upper right hand box, and the Order right below it. Switch the lower left hand box to Response, and use the Upper Cutoff Hz and Order to set the upper frequency response.
...The TH is kind of like a box and port all in one, so it does not suffer from port turbulence even with low tunings.
This is an interesting point of view. I'd turn it around: a ported box is a direct radiator still wanting to be mated with a good horn, but having to settle for a resonating box/port instead. It doesn't enjoy the same level of output SPL gain for a given level of diaphragm motion.
I really don't prefer the sound from a ported box sub: all ported boxes that I've heard have sounded sloppy, opaque, and overbearing once turned up to concert levels.
In a ported box, driver excursion is at minima at Fb, just as it is in a horn at Fc.
For a FLH to provide an excursion minima and 125 dB at 16 Hz it would have to be huge, TH and BR don't require as much volume, and would fit in the OP's designated chamber and provide the SPL he specified.
Hi Old Ears,
Oliver,
Thank you for your patience. I've been using loudspeaker wizard and filter wizard for some time working with TH. Hornresp is a powerful tool for those of us not ready to jump into Akabak.
Your BR design is perfect for what I need. And even using the $200 Dayton UM15-22 (since the 18 is not yet available) I can accomplish what I need with only 2 drivers. If I don't get a 1pi result from my strange speaker location, I'll just add 2 more.
Thank you again for all your help. It's forums like this that restore my faith in the internet.
Gratefully,
Steve Archer
Hi Old Ears,
It might be worth it to wait for the 18" driver, on the other hand if the 15" will do the job you could use a smaller box. Just make certain that you get the port velocity down into a rational range, that's all the output you've got at the bottom range of what you are shooting for. If you decide to give the 15's a try go with four, you'll loose a few dB because of power compression and port compression. Those losses are not accounted for in the simulations.
One more thing, Just wanted to point out another 21" driver that caught my eye at US Speaker, the RCF LF21X451 - $599.95. One of those comes really close to the design goal in a BR or a TH. Looks like one heck of a driver. Wonder if anyone has any experience with this one?
US SPEAKER Home Page Menu - Speaker Cabinets, Guitar & amp; Bass Amps, upgrades and custom design. The world’s widest choice of speaker parts. “If you have listened to live music, you have almost certainly listened to Eminence”
Hi freddi,
Post #50:"...PRV Audio 21SW4000 21"..."
This one doesn't want to go that low in a BR, but will get close in a TH, again, would be nice if somebody had any personal experience with this one. It used to be quite difficult to build that large a voice coil, and make it work in the long run, maybe all that has been solved by now.
The entire idea depends on the presumption that the *organist* is ever going to actually press the footpedal that *is* the 16Hz. note!
Still would love to see an actual picture of the location/wall/church whatever the building happens to be...
And, then too there is the heretical idea of (gasp) installing a few actual solenoid controlled air operated PVC made *organ pipes*!!
Hi Old Ears,
The example you are showing in Post #53 is by Don Snyder, and I don't know which drafting package he uses.
I use AutoCAD (an old version: 14). There are a lot of 2D drafting packages out there, a very full featured free 2D program is from Siemens (Solid Edge Free 2D):
Free 2D: Siemens PLM Software
Maybe do a Google search on "free 2D CAD"?
Thanks. I did search for a 2d program and just wound up with Sketchup which I've used for years, I just wanted something a little simpler for 2d.
By the way, I've been massaging the BR cab to utilize a 4x8 sheet the best and with a proper high pass and 80 volts (3200 watts!) I can get a theoretical 130db from 2 drivers! Might ought to put an extra fan on that Crown amp. I hope Eminence hits the June release date for the UM18-22.
Steve
  • UM18-22.txt
I second weltersys's statement on the Dayton UM 18-22, for that price and with the great customer support from Parts Express that's a very good deal. It may be a good idea to ask customer support what they think about that kind of installation.
