900W H-class PA Amp with Limiter
hey.. Stay cool sir.. Everting will be fine and success if we cool here ;).
thanks guys now my h900 is working, i clean the board with lacquer thinner,and test again.. now step up is working .heres my pcb thanks apex:D
Hi Apex,
just a question: Why didn't try the Crest step driver? It's quite simple, use just common components, and cheap.
Sajti
Hi Mile , warm greetings from Macedonia , i have experience with audio amplifiers :) Can you send me the full documentation about H900 ? (power supply board , amplifier board PCB layout , circuit and so ) I want to make stereo version of H900 :) Also , how much toroidal transformers i will need for this amplifier ? Just for the amplifier .. 2 kW will be enough for the 2 channels ? Maximum AC voltage should be :confused: Will i get maximum power with 2x55V AC 1000VA transformer for one channel or ???
And i still don't know why 4x40VAC ??? can't be done with 2x40VAC ?
And if it is needed 4x40VAC show how to conect the power supply to the amplifier board , sure with the layout pcb :)
greeting daniel.
I dont know why u ask that. Everything u ask is here, please read from first page, dont be lazy..
Regards.
