TPA3116D2 Amp
Disabled Account
Joined 2002
OK, would a better potentiometer in the same form factor be better ? I have 50 kOhm Alps ones that seem to fit. No idea what the value of the potentiometer on these boards is as don't have one yet.
Just ordered the YuanJing board which is on sale now at their own website. I am very curious after reading the comments here.
I know this might seem absurd but "if" these boards are as good as so many feel they are then maybe a very high end potentiometer like a Goldpoint Compare Attenuator Types would not be out of line. Seems crazy to pay multiples of the price for the potentiometer but if it helps get the max sound quality out well.......If others know of comparable quality at cheaper prices I'd love to know.
Here comes a link 1pc 4x24 Step Hi End Goldplate Attenuator Potentiometer | eBay
If it doesnt come up, Search: 1pc 4X24 step HI-End Goldplate Attenuator
Im new on this so i wonder what is the difference between, 24x2 and 24x4 (poles).
And the one i sent, is it ready to use? Its stepped attenuator but better price then the one you sent that was 150 usd. But maybe that one is much better?
There are plenty of great pots on ebay much cheaper than Goldpoint, not to mention all the LDR/optocoupler designs as well. Goldpoints are so ten years ago.:p
Can you explain why?
I'm sorry but you should really read some basics about electronics before venturing into trying to build a power supply from scratch. It will serve you well in the future as you will know why some things works, and others don't. I apologize if this comes across as blunt but at the end of the day there is no getting around learning it the hard way (by reading books).
Disabled Account
Joined 2002
You have to take into account that the 22 V AC will be approx. 1.4 x a DC voltage after rectifying and buffering. So lets say more than 30 V DC unregulated. The chip will fry.
For 22 V DC a 15 V 3 A (or more) "real" transformer (so copper wires around a iron/ferrite core) will work with a rectifier and large buffer cap. I would use 10.000 or 22.000 µF rated for 35 V or higher. You won't be able to adjust voltage and it will be unregulated voltage unlike switched PSU's. The chip won't fry but any experiments like running it at exactly 20.5 V won't be possible. Can't be beat for simplicity and reliability though. With switchers you have one certainty: they will fail, you only don't know when.
I am exaggerating of course but old fashioned transformers are reliable.
See this very simple schematic and use a 15 V transformer with primaries that are suitable for your local mains voltage and the 10.000 µF or 22.000 µF 35 V for C1. Use a diode bridge that can handle the inrush current. An 100 V 8 A rated bridge will certainly suffice. The ones with Faston connectors are easy to work with and most are rated way more than 8 A. The link matthtvr gave is a good one but for TPA3116 you don't need symmetrical supplies ( so +, 0, -), you only need + 20 V and GND. If all this is too much then don't bother and use a laptop adapter.
I measured it quite sometime ago. I think it is 100K
Or you can try this one.
Aliexpress.com : Buy Child 1195 100% cotton long sleeve dance clothes female child autumn ballet leotard costume from Reliable costume tweed suppliers on frank mo's store.
Quite a bit cheaper but only 21 steps. It uses SMD resistors, that's why it is so much smaller. There are other sellers at EBay selling the same thing at higher prices. The feedbacks on this step attenuator (at EBay) are quite good.
I have seen other variations using smd resistors too e.g.
ebay.com/itm/Valab-23-Step-Attenuator-Potentiometer-50K-Log-Stereo-/281138265590?pt=US_Amplifier_Parts_Components&hash=item4175257df6
