F6 Amplifier
Basically this:
Inverting one of the secondary windings on the transformer. Or will that result in no output?
Nice idea but if u try there will be no sound. If you want to play with SE using F6 i think is a nice idea anc quite simple, just disconnect the transformer secondary for the top fet and replace with a jumper wire. So the bottom fet drives the output, and top fet just acts as a load. Not an aleph of course so won't be much power but will be pure single ended ...... Edit: leave the unused secondary alone or can parallel for better drive to bottom fet.
Maybe F7
It is derived from the "Beast with a thousand JFets" by Mr. Pass. It has the simplicity and efficacy of his design doctrine, plus the usual front end of several FW amps.
Another thing I thought about:
If I've understood correctly the purpose of the transformer is to act as a phase splitter. If you already have a balanced source, would it be possible to skip the transformer, the feedback and just connect the inputs directly?
Hmm, the pursuit of knowledge continues...
Would this work or have I forgotten something this time too? ;)
And on another note, If I've understood correctly the F6 has very much in common with the JLH / PLH except that now a transformer splts the signal. And that the "sound tuning" is about letting one side doing more or less ( or equal ) load of the other side.
If one would go pure SE and disconnect the trafo from one of the parts would it be enough to connect a jumper wire on the then ccs side? Would be fun to build one and compare against my F2.
