Hello
Sorry i do not know so much about digital,,few question
shall i use the DEM chip when i will use DDdac spdif to i2s converter ??
what are the DEM chip for ??
is it ok to make the i-v resistor so high ,that i kan have 3v out ? (i use 6n2p Lampi for output ) i use now 75ohm for my pcm1794 --
Best Bjarne
Best Bjarne
Hello
Best Bjarne
You´ve got a PM!
Anyways, the treasure hunt is on for a tda1541a.
Did you see the offer on DuchAudioClassics.nl ?
For sale: NOS Philips TDA1541A S1 single crown
Hello
Best Bjarne
I'd like to know as well.
Hello
Best Bjarne
To get the maximum performance use all new modifications: Free running DEM oscillator mod. & 3.3V I2S attenuator mod.
You will find all informations about this mods in -ecdesigns- thread.
If you use a tube I/V stage, you should do also the bandwidth limiting mod. The recommended R I/V value for one TDA1541A here is ~56R.
Best regards,
Oliver
These 250v .1uf wima (16x) go into the psu, and the 100v .1 wima (4x) go into the shunts , right?
We have four 0.1µF caps on the Red Baron V4.0 and none on the shunt´s.
Please look in the RB V4.0 BOM!
Hi Oliver,
Regarding the mod to put SMD caps across the TDA1541 outputs to reduce bandwidth for distortion reduction at the SRPP 6n2p tubes on Tubizator, can I ask your advice please?
My two TDA1541A boards are modified Mk1 boards, and are soldered together with output wires, i2s wires etc., so access to the output of the chips is impossible for me, or at least undesirable. Is there a way to solder an alternative SMD cap across the inputs of the Tubizator? What size would that be for a 2 chip dac please?
Hi Oliver,
Hi Lucas,
John recommend to set the corner turnover frequency to 300...400 KHz. You could calculate the cap value with this online calculator.
If you have the recommended R I/V value of 28R (2x56R parallel) and could only solder two caps, than you should use a pair of 0.015µF SMD caps. Mouser Part No.: 667-ECH-U1H153GX5
These caps should be soldered as near as possible to the Pin 6 (AOR) & 5 and Pin 25 (AOL) and 5 of the TDA1541A, e.g. downside of one MK1 pcb.
hmm, looks like you don't add the caps in your reference psu.
But there are spots for 8 caps right by the diodes there. Is this where the .1uf wima caps go? (I got 16 of them).
Yes, that´s the place where you could solder these caps!
Two of the 1uF are in the onboard I/V stage
Ok, I don't think I need them?
Hello
Is the spif to i2s converter from DDdac ok to use with the Red Baron ??
or are there other way to go
best Bjarne
You could use every SPDIF to I2S converter you like.
Hello
best Bjarne
I would suggest to use Ian's Fifo buffer with its S/PDIF converter, so you can totally isolate the source.
I'm planning to use Ian's Fifo without the reclock board, running at 128fs (5.6448 MHz), avoiding any clock divider.
Ian's Fifo buffer provides 2 words of 64 bit each at 128fs (16 bit of music and 48 trailing zeros). The TDA1541 can run at 5.6448 MHz in NOS mode, discarding the trailing zeros.
In this way, one can provide the BCK directly to the DAC pin from the MCLK, minimizing jitter. The same MCLK is sent back to the Fifo buffer synchronizing the system, isolated from the source.
The only problem is to find an XO at 5.6448 MHz (I'm developing it myself).
Oh, these the caps for the tub-i-zator mod #2?
- Group Buys
- "Reference" TDA1541A DAC with I2S-BUS architecture
