that is a very high bias/low rail voltage v3. are you running low impedance speakers?
given for 8 Ohms, but having some heavy dips, I have an impendance curve somewhere...
I read the multiple power calculation in this thread...as everybody I'd like to stay class A as long as possible... but I need to re-read that calculations again
I assure you the PCB's won't be close to the most expensive parts. By the time you build the power supply and get enough heatsinking!
We've decided to release the rest of the boards right away, which means about a week for them to be in stock...
That should be this week then...
post2103:
is that 70degrees of phase angle at 4ohms @ ~40Hz
& ~45degrees @ 3ohms @ ~60Hz?
Those will be very demanding of the output stage and drivers with short term loads.
At 40 to 70Hz the tones could be quite sustained. Could high levels of these bass tones these blow up the output stage?
post2103:
Yes Andrew, that's the way to read the graph!
Hence ,my question: As much Power into 4 ohms as possible (higher rails) or as much "class A" as I can get from lower rails ?
Andrew,
I am totally willing to have a closer look, your indications don't help me though.
Could you tell me what you mean by SOAR - I am pretty sure not a jordan village or cognitive architecture.
If it's "Safe Operating Area" then I would just need a hint on where to find information on Bensen.
Thanks,
Max
Thanks,
Max
Hi all!
I'm interested in some of Tea-Bag's boards, however he has currently run out of them.
So if you also want some, please show interest here, so that he can produce a new batch: https://docs.google.com/spreadsheet/ccc?key=0AnAnd3RI56NmdGk2aHZ0dkVGRnc1ZzdrWm9lYzgtOVE
Thank you very much
Daniel
Thank you very much
Daniel
Usual Excuses: Family Issues, Day Job, other PCB/chassis issues...
BUT the circuit board sets are now individually labeled, packed and SENT by UPS to the order fulfillment center. Should get there in 2 days plus 2-3 days processing on their end and they'll be in the store. The fulfillment people are more reliable then I as it IS their "Day Job"
You have to get 2 sets.
http://www.diyaudio.com/forums/pass-labs/206756-f5-turbo-circuit-boards-209.html#post3469771
Thanks ....
output circuit board dimensions ...?
Any opinions ?
Yes ...
post2103:
Not if he runs enuff and keep them within SOAR....
Your amp will have to be able to sink power continuously into 2 ohm to not have bass issues when driving that load, noticed you have the port tuning at a low 20hz, what size driver ... ?
Thanks ....
Yes ...
Wayne,
quoting you " if he runs enough ****" , I guess you wanted to write bias "bias" ?
Driver is 15"
Max
- F5 Turbo Circuit Boards
