Stolen Trademark Amplifier from Jim's Audio on EBAY
Nice to hear it works fine with the new softstart Rudy! Very nice softstart btw :)
Well friends again a little update. I was just checking the mail and I received some Rhodium IEC connectors from China which I ordered a few days ago:
Sound is much more open and dynamic with this connectors now.... haha nah, I don't believe in magic. But they sure are nice! I thought this kind of connectors would be very pricey, but actually they were fairly cheap, bought them for 17 dollars with shipment to Holland! Have to buy some nylon sleeves and some cable so I can make a nice power cord.
And wired one side of the interlink between the fancontrol and amplifier:
Little circuitry
Thanks Dean!! :D
@BMW850; Hi Rudy, thanks for your input! I will try this little circuitry. I am curious about the results. Nothing causes problems, only my laser printer. It was a cheap one, so probably it's PSU allows applying a large DC-component on the net and is not proper filtered.
By the way,Rudy, did you solve the problems with your softstart?
Can you put this little circuitry in the laser printer?
...to raise a topic:D
I received a new toy from Hifi 2000. I was browsing the Hifi 2000 website the other day and noiticed they are offering new top panels with more ventilation holes. Temperature is managable very good right now. Temperature is idling about 65 degrees Celsius at the hotest part of the cooling tunnel with bias slightly dialled down to 450 mV (which is more than enough for me and lengthens the lifespan of my KSA a bit more). But offcourse the more ventilation the better, and since this panel was not that expensive, I decided to order a new top panel.
I think it looks very nice but more important it is very functional, there is more ventilation from the surroundings :)
Hello hello hello another update from Hollandddd :hohoho:
Finally I had some leisure time so I could finish the D-Sub cable. The cable turned out really nice, a nylon sleeve can do wonders concerning esthetic looks :)
I've also made a little PCB so I can connect the four fans and for temperature sensors very easy to this PCB:
Also the D-Sub chassis part could be easily connected to this PCB via a little 25 wire flatcable.
Result (don't mind the mess :D):
Works like a charm :cheers:
Joined 2005
The original KSA 100 used an orange (not sure maybe ICC ) 250 VDC 0.1 uf polyester cap with 2 watt 5% 5.6 ohm dark brown resistor - not sure who made it, for the zobel mounted at the output jacks - a good film and foil polypropylene with an flame proof 2 or 3 watt metal oxide or caddock power film resistor will be a good upgrade. It was stable with Quad 63s in parallel with 4 ohm Dynaudio subs.
Amices,
Any progress made ? :) I am still enjoying the KSA. Glad it is still operational. There have not occured any flaws. It is and stays solid as a rock! It is really the beast amplifier I've ever heard. Krell really is a fantastic brand :D
I did some further experimenting concerning the optimal bias value. I've found out that 450 mV bias (when using 1 ohm emitter resistors) is the optimum value for my KSA when concerning heat, stability on the long term, noise from the fans and distortion.
Looking back I've learned that using two seperate cooling tunnels is the best solution when going full bias. There is more difference in temperature between the cooling tunnels than I had expected (about 12 degrees). This causes one part to get very, very hot (70+ degrees). Although the trannies would be well within their SOA, I did not feel comfortable.
If I ever would made another one, I think I would buy even larger tunnel coolers and place them upright, just like in the original design. Maybe in the future... I still have some parts left haha :D
I've also bought a nice, but defective pre-amplifier! Risking of going offtopic, I hope it is still nice to tell you all a bit about it. Got to keep busy aye ;-). I was thinking to use the chassis and replace the intestines with a design from Pass. But I actually liked the amplifier and tought it would be a shame to stripp an expensive amplifier like this one just to use the chassis. Also I did not expect it would cost me a large amount of money to repair it. So I decided to repair it. It is a Pre 6 from Audyn (a Dutch brand). It has been custom made and is pretty expensive (about 1650 euro's!). It has 6 channels, so it is actually a 6 channel pre-amplifier. Two channels did not work. I found out that this was caused by two defective modules, which I tought, were customly designed by Audyn. I was expecting something like a PGA2310 in it, since I was most certain this module must had a function as volume controll.
So I've mailed Audyn and Aaron (Aaron is a sister company derived from Audyn). I've asked both for a schematic and what a new module would cost me. Aaron could not help me because the Audyn amplifier would be completely different than their No.22 device. 'AARON and Audyn are not the same. Even if they are based on our AARON technology, they are all cheaper made and the sound is of course not as good as the AARON amplifiers'. Hmmm, maybe I need glasses, but compaire yourself:
Aaron:
Audyn:
But well, it does not really matter. After all it is an Audyn so they should be the ones to help me. After many e-mail traffic with Audyn, giving the serial number and so to them, they still refused me to give me a schematic or sell me another module. Even a partnumber of the module was to much to ask. Only thing they they offered me was the option that I would send the device to them, they would repair it for me and charge all the costs (starting with 80 euro's for just 'inspecting the device'). Well you see my friends, price is not a good degree for the level of service you may expect.
Well okay, keeping positive, thus till so far the nagging part. It is time voor DIY. Like I've said earlier in this treat, having little budget forces you to be creative. So I carefully sliced a module open to see what actually was in there. I had to be very, very carefully. Any printing on the electronics inside is erased easily.
Tadaaaa:
Whaaat, it was just a plain simple Maxim DS-1808 IC! Not expensive at all :eek:
So I've bought a few of these IC's from Maxim and a few SO-16 converter PCB's from Ebay:
Resulting in new modules!!!
It is almost a crime if you think about what these kind of companies are charging you for what actually turns out to be a prettty simple amplifier.
I am using thes pre-amplifier in combination with the Krell. I have to say, it sounds pretty good. It is hard to describe, and a bit cliché, but I experience this pre amplifier as very open, direct and analytical, but also a little 'cold'.
It also combines very nice with the Krell if I may say myself :p
Conductive Rings
Good job David!!! I also got a reply from Jim:
Thank you very much for building the boards with patience and shared your experience with other people. I have checked the board, and it seems to be an error that happened during PCB fabrication, since in the first log of boards ( I built two logs, and the first log was done in 2007 - 2008) there is a link from the track ( right below the transistor MJE15033) to the base lead of this transistor. I need to check with our PCB vendor why this happened. But I thank you for letting me know this otherwise I thought the board is as good as it has to be.
Nice that this mystery is solved :)!
By the way David, there is another thing you have to take into account. Around the holes which are meant to attach the MJE15033/32's to, there is a conductive ring:
When you attach a non isolated / non anodised heatsink, which means your heatsink electrically is conductive, chances arise that your heatsink will make short circuit due to a connection with these holes. This holes are connected to the the collectors of all MJE15032/33 devices. Short circuit between the collectors is something you definetely don't want, because your power lines will make short circuit also (V+ and V- are attached to the collectors). So you have to isolate the heatsink from this rings aswell, or use an isolated heatsink. I took no risk, so I chose to remove the conductive layer on the surface around the holes in the front by drilling very carefully the little conductive surface away. Worked like a charm :).
@Dean: Aha, so you have the red ones too. I thought the blue ones were yours :-D. Hmm, maybe Spurtle is lucky and have his PCB's the tracks aswell.
I finally found appropriate heat sinks for MJE15032/33 devices and somehow luckily ran into your advice. The only thing, I will have to attach the devices vertically. I am still having a hard time finding the appropriate fan type heat sinks for the output devices and since reading Fix's old posts, that he really found that his music went sour with lower bias--below 500mV--to deal with the heat dissipation--he wanted ~625mV because his music was bliss at the higher bias (the bass). I am really thinking of liquid cooling (mineral oil?).
Hi David,
I have to say, in all honesty, that I do not share the observation Fix has made. I actually can't hear any difference when experimenting with bias values ranging from 100 mV and up. I begin to experience slight deteriation in sonic quality when I dial the bias far below 100 mV.
But I have to say, I don't listen music at very loud volumes. So the amp has not to deliver lots of power to drive my speakers. That is why, in my case, a lower bias will do just fine. When your speakers draw more power than your bias is set, and you exceed this value, then you can experience more distortion due to crossover distortion, but below it should not occur.
But cooling is very, very important. Lot's op people underestimate it. I for example did haha. That is why I want to add even bigger tunnel coolers because 1) I am bored haha, 2) because this way the fans have to displace even less air to get the same results and 3) because I offcourse want to go all the way ;-). After some evaluation I think it is after all beter to separate the tunnel coolers afterall, and place them upright just as fix did and the original KSA-100 has.
If I am correct the original KSA-100 uses tunnel coolers which are 12cm long. If I am not mistaken Fix is using tunnel coolers which are about the same length. Even then I think the KSA-100 runs pretty hot. So you will need probably more cooling. For my new plans I have bought these beauties (29cm long each, almost twice as heavy as the ones I use right now):
I am thinking of cutting them through at about 18CM and place them upright. Does anybody has some experiencing with cutting aluminum profiles like these?
Liquid cooling would be very verry cool David! I would love to see that. Even better, it does not produce a lot of noise. I think for me that would be a little to expensive. I think I stick to aircooling.
Hi David,
Due to the size of your heat sink, if you want a nice cut, try to go see a machinist. They will have the proper saw to make a nice cut. You can always use a hand held steel cutting saw, however the result will be proportional to your ability's to handle it. i.e. you might end up with an uneven cut requiring a couple of hours of filing...!
Eric
Joined 2005
Yes the original KSA 100 used a tunnel heatsink actively fan blown.
It really wasn't big enough for the 2.5 amp bias current and baked the thermal compound under the output devices into dust over time requiring a rebuild of the output stage. It needed a bigger sink or a higher ( noiser) fan speed.
I rebuilt mine as a Borbely Millenium with Hitachi TO3 Laterals biased at 1.5 amps and it's been good for a decade.
Hi Eric,
Thanks for your input! I was wondering and also a bit afraid that using a hand held cutting saw is not going to be a great idea. I was hoping it would be possible when using a saw guide, but you got me doubting now :). Think I have to contact an ironshop indeed. There are some metal shops here in the neighborhood. The profile can be dissassembled into 4 separate sinks by the way. This is one of the four heatsinks per tunnel:
I am still enjoying the KSA as it is now, so there is no hurry. My plan is to overhaul the KSA again when summer break arrives.
@Ticknpop; I was really doubting that cooling in the original was sufficiënt. Glad to see that someone can confirm this. Even in my present lay out, there is more cooling capacity than the original, but even now it gets pretty hot. This is mainly due to the large distance cold air has to travel through the tunnel. This results in one side at comfortable temperature, the other side running pretty hot. So I am not really comfortable with going full bias right now. Therefore I dialed bias down to 450mV. I think using the new tunnels and placing them upright (so separated from each other) will be a big improvement. I can also attach larger fans to these tunnels than to the ones I am currently using (12cm or even 14cm with convertor vs 9.2cm right now). I am thinking of using 18cm long profiles. The new profiles are the same size as the original, but mine will be 50% longer compaired to the original. Hope that will do.
I am very curious to your rebuilding! Do you have some more info? Maybe pictures? Did you convert an original KSA-100 or did you convert an DIY KSA-100?
Hi Eric,
If you have a guide, you can use all the way through, then do so as long as you properly hold your heat-sink in place. If you have a piece of scrap you can try on, do so first to get a feel for your saw.
Eric
