Class D Amp with LM566, LM393 and 2XIRF530
Hi Hadi ,
Please reduce your photo's size by using ACDsee software.
also , for you videos you can use IMtoo total video converter and convert your video files to another format with lower size.
anyway , i think you are using different mosfets , am i right ? you are using IRF640N isntead of IRFB4227 ?
Mile ,
thanks for good circuit..
how can we increase the output power ? for example 400-500w on 4ohm.
IRSound
Hi Hadi ,
Mile ,
IRSound
D200 power is 400W/4R (with IRFB4227 and +/-75V DC rail)
Thanks Mile ,
i attached three photos about Crown XLS1500
the rail voltage of this amp is about +/- 75v same as D200 , also this amp use a pair of TO-220 in output stage , but crown claim that this amp can handle 300w @ 8 Ohm / 525w @ 4 Ohm / 775w @ 2Ohm
how it's possible ? :confused:
Regards ,
IRSound
Thanks Mile ,
Regards ,
IRSound
Crown XLS1500 use regulated SMPS in PSU, with SMPS D200 have same power as Crown.
