QUASI Amplifier for Beginners
Oops!… I Did It Again
I built the amplifier with two pairs of transistors and it works with +-40V DC. The Sound ist great.
Thanks apex, very nice for beginners (like me ;-)
Olaf
Olaf
Hi olafk!
According to this schematic, where you worked?:confused:
Since the standard schematic error is ( take a look topic?!)
Such should be!!!
Cheers!;)
hi Apex sir,
Currently using this amp with 5 pairs of 2n3773,supply 40-0-40 AC 1.5kv traffo,20,000mfd caps per side on 4 ohm load. sounds good to my ears even as full range amp but currently coupled with your 2x12 inch subwoofer enclosure in a three way system.
What output power i should expect from this ?
hi Apex sir,
250W on 4 ohm load with 40-0-40 AC, can you post pictures of your sub?
Very hot
I built the amplifier (picture see post #663) with two pairs of 2N3773 and I use +-60V DC. Now the Transistors MJE350/340 become to hot. I can touch them for only 3-4 seconds and I think it is a bit critical.
Should I reduce the voltage (have regulated power supply) or are there any other things I can do? I changed the heatsink to a bigger version for TO220 like the MJE15030, but gave no better result.
Can anybody help me?
regards
Olaf
regards
Olaf
Nice work, MJE340/350 work in class A and must be hot but use 100R resistor instead 56R around MJE340 and this will reduce current in VAS CCS and disipation on MJE340/350 also.
Can you share your pcb?
