Studio Reference Amplifier
Ok, mas Jofual.
this is the pdf for toner transfer.
PCB size is 68mm x 200mm (saya kecilkan sedikit)
& you must set "mirror" setting on the printer.
Do have a laser jet printer?
I don't have & tried photocopier but not good, I end up with "spidol" permanent again :D . I will try another way to make PCB.
No component value!
You must find by your shelf where is component value,
because I usually not make it.
I like PCB without silkscreen :)
There also .pcb file, but I rename it to .txt
you can try open it with ExpressPCB after rename it again
Enjoy ...
Hi mr John... now I already put all component value.... please you check are all the component value write corectly..?
Hi all, thanks to apexaudio for great schematic...
Finally I made SR200 with same value with schematic, here some pictures
(but sorry picture is not good quality)
I use 220nF/63V on VBE & 100pF/100V on colector of the driver transistor
because that what I get here, so what is the maximum voltage that I can use?
The first design, megusta more. :superman:
you could also upload all your data. :)
thanks.
Quick action... :)
Use 2 x 0.68R/2w not 2 x 0.33R/2w.
I use 1 x 0.33R/5w on my build.
Next I will try 2 x 0.68R/2w & the position is in reverse each other to minimize the inductance, maybe...
thats what I'm thinking.
@SERGIODS,
sorry I don't have with component value...
better this new layout :)
Quick action... :)
@SERGIODS,
Ok Sir John .. this the new corect one.. and I also corection the resistor 10R from pin 3 IC to ground... thanks for share sir..:D:)
...... sorry , was modified so many times ..... forget to make connection ;) but the silk screen it's the same . In the post#707 it's correct ......
Alex.
  • PCB SR 200 REV 3.1 ALL.pdf
  • PCB SR 200 REV 3.1 B&W.pdf
Alex.
Hi Alex, I have most of the parts for this amp. Can you please make the pads of Q9, Q7 and Q8 a bit bigger? really appreciated your endless efforts for making a PCB layout which beautifully executed.
BR,
Junie
