Well, the IRFP244s that I so carefully matched into groups of six have now been mounted onto the output PCBs.
Time to see how close my matching was at something like the operating current that they will be used at:-
Board No.1 0.7% Not Bad
Board No.2 0.5% Even Better
Board No.3 2.0% Worse but still very good
Board No.4 was just about to be tested when the doorbell rang.
The percentage figures are the "match" between Vgs as measured across Rs on each MOS-FET. They were tested at Igs 2.4A/6 = 400mA and Vcc = 24V. In the final circuit they will be at Vcc = 48V but the same current.
I can't seem to find any advice as to whether it is better to have the better matches in the current source or the amplifying device position.
On completeion I'm going to have LOTs of IRFP244s left over, most of which are matched into close pairs.
I'm now in the process of putting the whole beast together.
I did have a worry that the bank of MOS-FETs on the rear panel would not be adequately sinked.
Interesting.
FET No6 on the right hand side of the bank gets quite hot, even though it is on 10mm Ally plate which is shared.
Obviously the single heatsink on the rear cannot dissipate the heat of the F4 but I would expect the heatsink on the left hand side to get hot.
Why is the heat not being shared around the enormous ally chassis ?
Everything has been polished and coated with a "smear" of heat transfer compound.
Interesting.
Finally I gave into "Mr Fan". The PABT 24V 120cm fan running at 10-12V is almost silent. With the fan running and the rear bank biassed at 25V and 9A (250W) the MOS-FET side of the hestsink is at a comfortable 45 degrees and the outside almost cool to the touch.
I would like to try and get the fan inside the case though, not because it's noisy but because it spoils the sleek lines of the design.
My intention is to fit a pair of heatsinks on the inside of the case and cool them with fans. a) this will reduce noise further, b) they will be cooling the MOS-FET side of the chassis and c) it will look better.
this will not reduce noise. you will get at least 6-12db more noise because of the forced airflow inside the chassis.
All 24 MOS-FETs now fitted and undergoing LOAD TESTING to ensure that HEATSINKS are adequate.
I hate the fan on the rear but I can't seem to find a better way of getting rid of the heat from the fouth side. You cant see it anyway and the 24V fan running at 9V is virtually silent.
I was very impressed with the MOS-FET matching, all four bankc are within less than 1%.
I'm knackered. Cutting 10mm Alluminium Plate by hand is hard work.
Still in the true DIY spirit, I am not going to cheat by spending hard earned money when it isnt necessary.
This is the bottom plate being manufactured, it needs to be so thick in order to support the enormous weight of the build so far plus the two massive toroids.
Now for the Power Supplies.
I am using 12 x 33000uF Dubilier Computer Grade Capacitors. They actually measure at nearer 90000uF each.
There are four banks of three caps, one each for LEFT +ve LEFT -ve, RIGHT +ve and RIGHT -ve. 100000uF in each bank (or 300000uF as measured).
I bought 4 x 22mH Air Cored Chokes and 4 x 0R47 25W Resistors.
Question is, What combination of CRCLC will give the best results.
Quote>I'm knackered. Cutting 10mm Alluminium Plate by hand is hard work.
For straight cuts Forghet the hand saw and the Jig saw much faster and accurate with an angle grinder and metal cutting disk.
You could get the 1 mm thick ones and the 4 1/2 in grinder can be bought for £20 £30.
Just let the disk do the work keeping light passes against a straight edge there is a knak to it less force and more patience is the secret.
I built the Vauxall plant with it (well my share of it)
On the caps what do you use to mesure them my meter gives up at 10mU
- Aleph 4 Strickly DIY Project Build
