Konzert Amp & Speakers Website
Sir im going to use the CA25 for driving the 302B sub clones of sir Jojo.
ill be installing it with two 12" JBL GT sub with 500RMS ea.
will this amp better to drive this?
Uploaded with ImageShack.us
http://img834.imageshack.us/i/unledqmzd.png/
Uploaded with ImageShack.ushttp://img823.imageshack.us/i/dsc06190is6.jpg/
JBL GT-512? I don't know if four 2 inch voice coil would be able to handle the power of a CA25, theoretically it would be equivalent to an 8 inch voice coil (wired series parallel) but its weakness is the large xmax. Meaning it has a large number of winding expose to air.
Sir what would be the best amp sir? or should i look for a more longer excursion subwoofer, is there such a 12" sub with 4in coils?
sir looking forward for your recomemedation if i would just go on a lower model CA amp or change the subs sir?
im really looking forward to that punchy loud bass
thank you po!
thank you po!
yes there are 4 in voice coil driver even with a 5 in. If your going to use these for a "live band" go for a pro driver not car audio drivers. crown makes an affordable 12" driver (crown jh-126) with a 3 in voice coil. Crown - The Professional Choice
They say that Soundstandard's CA20 is equivalent to Crell's CA25 and the internal circuitry is way much better than the Konzert's K series. You might also want to consider Lexus amp. Just my 2 cents.
@audiomachines
@dj_jojo_md
@diyers
sir, if you have to buy one which would you prefer Soundstandard CA18 or Crell CA20? please give your opinion sir,.. salamat
Just finished...WSX and MT122
Magandang araw,
jojo
Parallel Series
@ dj_jojo_md
@ Audiomachine
Sir, how is the connection of the line array speaker? series/parallel? what would be the rated ohms? number of amplifiers to drive with this setting? please share the schematic diagram for the connections sir, . . thanks. . .
To Sir Jojo,
Sir good day,, i just want to ask why..W box bin made in RAON has a pitch of 8" in the compression module...while the speaker plan W-Box bin that you have post is only 6.5" ...which is better in the name of sub...can you explain...thanks in advance..
Sir...I can't get it...if you can post some drawing the better...anyway...the plan that I have posted was the original version from year 1977...so it's the right dimension...
Have a nice day,
jojo
