@ sir jojo,
sir the mt122 do i need to put damping material inside. pls give advice
thanks sir
Yes Sir you really need to put some damping acoustical foam to lessen mid freqrency cancellation...
Have a nice day,
jojo
Have a nice day,
jojo
the foam from a bed this can be used because in our place is hard to find acoustical foam.
i just painted my diy box
Thanx Jojo
@ irvynejay
what kind of speaker and compression driver did u used?
rod
No can do Sir...and it'sgoing take some space (displacement)...or maybe you can use this synthetic pillow fillers...i think this will be better than what you mentioned.
Have a nice day,
jojo
Sir...I can't get it...if you can post some drawing the better...anyway...the plan that I have posted was the original version from year 1977...so it's the right dimension...
Have a nice day,
jojo
gooseneck,
please check the plan you are referring with,
you can check this link,
http://www.speakerstore.nl/public/images/constructions/w-bin_keeles/Keele_W_Box.pdf
and check what no. you are referring,according to plan.
or this attachment
k sir engel..thanx for the reply...what about your box sir...how do make your w-bin...did you retain the original dimensions...or do you made any changes with it..?tnx benny
gooseneck,
read post no.514 to 515 and post no.1069
lots of words from forum box expert,try to use the ""SEARCH THIS THREAD''
and read all related article
good day to all
@jojo
sir on the wsx box what kind of gasket material you used on the speaker access cover?
bec. the one on my wsx is silicone its hard to re-open again.
thanks,
rod
Sir...3M rubber foam tape 3/4" width...Avail at ACE Hardware...I always place the tape in the cover side then candle wax the opposite lid for easy release .
Have a nice day,
jojo
Have a nice day,
jojo
thanks sir jo
To Sir Engel dela pena, Thank you sir for your reply...sir can help me not to experiment anymore with this W-Box bin and WSX...coz some of our diyers have already perfected the right dimension of the compression chamber of the W-box bin and WSX...and i'll be using Crown 1860 for this boxes...sir can you give the exact dimension of the compression chamber..? of the W-Box Bin...what about the WSX...does sir jojo modified also the compression chamber...?
thanks benny
thanks benny
To Sir Audiomachines....
sir good days po...can i ask you a favor...?...if you have the plan with its dimension of the Extended Cyclops CBe-18 speaker box, please send me a copy...coz as i see...i think it's better than the W box bin...thank you sir...waiting for your reply...
benny
benny
to Sir Jojo....
Sir good morning...can you please send me the dimension of the Extended cyclops CBe-18 speaker box...the one that you made already...thanking you in advance...and hoping for your reply...
benny
Sir...thanks to stipe...he design it...the credit is not mine...To Sir Jojo...
Thank you very much sir....for the Extenden Cyclops CBe-18 plan...regards and more power...long live...
benny
have a nice day,
jojo
- Live Sound
- PA Systems
- Konzert Amp & Speakers Website
