900W H-class PA Amp with Limiter
hi apexaudio
greetings finished tlo 72 step driver pcb is the circuit in post 402
correct way to wire step driver to amp .Have made your supply pcb and
torridal will post pictures today after wiring up the amp
thanking you
andrew lebon
hi apexaudio
greetings thanks for your reply tracks are made stronger by 16swg
copper wireand solder this pcb is for testing purpose only i am trying to use
your step driver circuit with this amp.Have changed .1 to 47 pf but will recheck
10 uf polarity
1 you have used tlo 72 cp low noise does cp version tlo 72 results in lower
switching noise
thanking you
andrew lebon
is your vertex amp 3 step h class supply
