900W H-class PA Amp with Limiter
power up a bit
yes i am....:D
I install the zobels right at the speaker output terminals, you can use anywhere from 2.2 to 10 ohms....the thing is, carbon comps can be used here and if you are palying your amp loud, you better get several 2 watters in parallel if you want those resistors to last....
Hello Master Tony, Apex, gurus,
As I need to boost up this circuit a bit to 600w at 8 ohms, (as per Apex, this delivers 500w @ 8 ohms), what's the simplest way to modify it?
increase voltage?
add power outputs?
TIA & Regards,
Joel
increase voltage?
add power outputs?
TIA & Regards,
Joel
Increase rail voltage to 120v-60v-0-60v-120v, and you have 650w at 8 ohms, but 4 ohms will be minimum speaker impedance. With 110v-55v-0-55v-110v rail voltage you can run 3x8ohms (2,7ohms) speakers in parallel per channel.
This pcb design by 'coolet' use TL071 for step driver.
