900W H-class PA Amp with Limiter
hi apexaudio
greetings is the 2500 watt circuit for diy understood no pcb for
this project can 2sc5200 be used in output stage for same power reason i ask
in my city for one pair ofmjl4281 we can buy 7 pairs of 2sc5200
1 is it 2step or 3 step voltage supply for 2500 watt circuit
2 you told me with 50 100 150 50 100 150 supply it is possible to get 2500
watts from 10 pairs of 2sc5200 3 step hclass
any schematic for diyers no pcb no problem can make pcb with hand
thanking you
andrew lebon
I don't want share this H2500, this is dificalt and expensive project for diyers, but if someone can design his own pcb it is posible to build 3 step 2,5kW class-H amp. You can use 2SA1943/2SC5200, but test amp first, before use in PA.
hi apexaudio
greetings any schematic for diy 3 step supply h class supply
that you might want to share if you dont want to share its ok i repect your
feelings can you tell me if a 3 step supply is used for h 900 wii
1 heating decrease
2 more output power be given out and most of all can such a supply be
used with this amplifier the reason i ask is to learn experiment and how to apply
these 3 step supply for knowledge cant keep on copying have to learn fundamentals so please understand for me your h class power is amazing h900
similiar to qsc isa750
thanking you
andrew lebon
hi apexaudio
1 heating decrease
thanking you
andrew lebon
H900 can be redesign to work in 3 step classs H with more outputs, and you have heating decrease and more power,
Hi Apex
check schematic from PA amp M10
there is PA Amp with easy linear Class H Stepdriver without IC ...how do you think about this ?
Can I use this linear Class H Stepdriver for quasicomplementary output stage ?
I think it should work because its not switching Rail compare to H900
  • M10_Schematic.pdf
Hi..Apex, that's my pictures H900 still in progress:
1. Front panel:
2. Rear:
3.
