Pics
FS AR PL-100 Subwoofer Plate Amplifier, NOS
Selling a brand new Acoustic Research PL-100 plate amp.
Here are the specs from Parts Express. PE is sold out. But I have a few of these!
$50 + shipping
$50 + shipping
AR PL100 100W Class AB Subwoofer Plate Amplifier
Acoustic Research built the PL100 100 watt Class AB subwoofer plate amplifier to power a ported 8" subwoofer. Not only does this amplifier feature speaker-level (also known as high-level) inputs for signal, it also has stereo line-level (also known as RCA) inputs, as well as an LFE input for connection to the subwoofer output of a home theater receiver.
A variable 50 to 150 Hz low-pass crossover is included, as-is 0/180° phase control and an Auto On circuit. Spring-loaded wire terminals are offered for both input and output. Subwoofer volume is controlled by a plate-mounted control, and 1/4", as well as 1/8" female disconnects are pre-installed on the amplifier power output. A 6 ft. power cord is permanently attached.
Specifications:
• Power output: 100 watts RMS into 4Ω
• Power requirements: 115 VAC, 60 Hz
• Power consumption: 200 watts
• Dimensions: Overall: 9-1/8" H x 7-1/8" W x 3-1/8" D, Cutout: 8-1/8" H x 6-1/8" W.
FS: 8" AR woofers, multiple applications...AR17, TSW, etc..
Selling some NOS Acoustic Research replacement woofers that can be used in multiple applications. 8" poly cone. Model # 1210152-5
I also have some 1210153-1, 1210140 (just one of these), 1210163, and 1210132.
Great for DIY, subwoofer, replacement woofer, etc.
$50/pr Shipped, or make me an offer on multiples.
FWIW, Simplespeakers sells these for $80 each online.
Do you still have the Legacy II tweeters?
Let me know what you need.
More stuff coming. CLEANING OUT!
For Legacy I, Laureate and others, Part # 85000017, $20 each (I have 6)
For Legacy II, Part # 99-20167, $20 each (I have 4)
For Prodigy, Part # 99-20107, $15 (I have 1)
For Legacy III, Heritage and many others, Part #99-20240, $20 each (I have 4)
Pls add appropriate shipping.
- Vendor's Bazaar
- FS: Various items
