PP Triode Choice & Output Impedance
Thread Tools
Old 1st February 2021, 01:29 AM   #41
JasonWatkins is offline JasonWatkins  United States
I built a stereo/pair of the cascode schematic using the non-doubled supply. It turned out to be 184 volts under load, so a little higher than I remembered. The only thing I changed was the cathode bypass cap since I didn't have a 150uF on hand. I put a 330uF in instead. I took two 6GC5s and triode-strapped them for the output. That was suggested earlier for 6V6s and I happened to have two 2.5k edcor OPTs very similar to the 12k ones I just ordered. These are just the SE version of the same series. It sounds really nice. Fat and punchy I guess but that's what I like. Current is still a little low but this is night and day better than the resistance coupled circuit that I played with earlier. I can still build that and take measurements if it would be helpful.
  Reply to this post
PP Triode Choice & Output ImpedanceHide this!Advertise here!
Thread Tools
self-split dual triode output impedance? Illinest Instruments and Amps 12 14th June 2014 12:41 AM
Advice sought on impedance choice for DIY sub on a TDA2030A BTL amp Eschatonic Subwoofers 2 28th November 2012 04:30 AM
Recommended primary output impedance for triode strapped EL34? G Tubes / Valves 12 10th August 2005 10:32 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
