Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Tubes / Valves All about our sweet vacuum tubes :) Threads about Musical Instrument Amps of all kinds should be in the Instruments & Amps forum |
Thread Tools |
#41 |
I was going to let this thread die (not the project - I'm waiting for many Covid delayed parts) but I've run into an interesting dilemma. Early on there was a comment that it is unclear if the triodes from the 12AC10 would provide enough gain at on 96V B+. I put that on the back burner for a while but I've now gone back to looking at it.
So now I'm looking at gain stages using different tubes and I keep coming up with options with too much gain! Given the curves offered by Mona I need to keep the signal to roughly 8Vp-p. Assuming even slightly less than 1Vp-p in from Bluetooth I keep designing gain stages that give me 15Vp-p output from one triode. Not the ones from the 12AC10 mind you but from a couple of the Soviet triodes like the 6N16P. |
#42 |
With a ECC82/12AU7 LTP you get a gain of ~5x.
If that is still to much, apply some NFB. Mona |
#43 |
Thank you again. I appreciate your numbers but, as with the power output from the 12CA5, I'm happy to sit down with the data sheets and web sites and work through the design.
Figuring out the gain for a LTP is one of the things on my list. So right now I've simply been looking at single gain stages and knowing that if I add a LTP after if I will get at least a little more. |
#44 |
You are a teacher? Hope your pupils are more receptive!
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Crowdfunding for vacuum tubes/nixie/neon/scientific glassblowing workshop | customnixies | Everything Else | 8 | 25th April 2016 06:15 PM |
Advice for first DIY project (MIDI sample playing instrument) | mojbro | Instruments and Amps | 6 | 6th September 2013 04:52 PM |
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB | mclsound | Swap Meet | 7 | 26th July 2013 11:10 AM |
Does anyone have the a speaker workshop project with Seas 27TBFC/G measurements? | owdi | Multi-Way | 1 | 3rd August 2006 04:06 AM |
Audio Workshop D3 Kit | lawbadman | Digital Source | 16 | 26th April 2006 03:58 PM |
New To Site? | Need Help? |
