Audio Innovations S200 Schematic request
Dear Oracle,
I have an Audio Innovations set, 1x S200 Preamplifier MM model, and 2x 200 MK2 power amps.
I want to install the MC section and upgrade the preamplifier.
I need the schematic for the preamp, does anyone out there have one or know where I can get one?
I already have the power amp schematic.
Thank you
If I remember correctly it was the original AI 200MM schematic.
Hi Euro21,
Thank you for the schematic but it seems that it does not agree with what I have on the bench. I notice that my amp has 4x 0.47uF caps and your schematic only 1? I have attached a picture of my amp for clarity. If you have any other leads or schematics that would be great.
best
Steve
Thanks again Euro21.
I have read the thread you directed me to....very interesting list of mods. I want to try a few, so do you have any details? Like;
AI200 tweaked:
- HEXFRED diodes in both power supply (high voltage, heater);
- CRC snubbers in both power supply; Have you values and positions?
- 5 H choke in HV supply (C-L-C); Have you values and positions?
- BlackGate supply capacitors; Which ones are these?
- NOS Sylvania (3 mica) 5751 tubes in first positions;
- NOS Tungsram ECC82 tube;
- LED (green) bias in first and second tubes cathodes; How does one do this?
- AuriCap coupling capacitors (0.22, 0.47);
- direct phono input, Cardas RCA, silver coax; How?
- Vishay S102K phono input resistors;
It was the early "Quasimodo", like this:
TJERET FILE: Snubberized power supply (Quasimodo)
There is a resistor between first and second HV capacitor. Change it to choke with appropriate DCR (if I remember correctly it was larger than power transformer).
I tried to change six 47uF 400V capacitors to BG VK ones (it was a pricey game), but later remove its, and change all to Rubicons.
I killed R//C in cathodes, and exchange its to old 5mm green LEDs.
direct phono input
I inserted Cardas RCA sockets in the rear side "MC" holes as direct phono input.
There is a (input) ribbon cable in the front of the main panel.
I killed it, and connected directly to pins the input shielded cable from RCA.
Euro21,
That is great....
Have you a diagram for your LED mod, I do not understand how this works or where it fits in the schematic? Do you mean; replace the 220u cap // 3k3 R and 220u//3k6 R in the schematic with green LEDs? If so, do you not need a resistor to limit the LED current?
