EL84 Parallel SE
Then I didn't understand what you mean by "flexible".
However, I went on ... I started this thread with a largely wrong schematic and now, thanks to the help of all of you, I have a correct schematic that has evolved gradually taking into account also the materials I have ... in the meantime i started building it and I learned more about what I'm doing, it doesn't seem small to me.
You were building a 6Y6 SE amp in another thread just a few days ago. Did you finish that project? What results did you get?🙄
I had already built and listened to it ... then I followed your advice and I slightly changed it but I haven't listened to it yet ... it will sound better than the already good one that was before, i guess ...
I can't listen to it because it's set on a container that has a series of transformers, switches and a part of the power supply that is common to all amplifiers.
Unfortunately I can't work on it too long every day because I have severe back pain so when they become unbearable, I have to do something else. In the meantime I'm thinking of designing an amplifier similar to the one with the EL84, but using 2 6Y6 and, as a preamp, a CF that however uses 2 different tubes for the 2 stages (for example 6SL7 + 6AS7), but I'm still not able to do it alone.
I completed the makeshift assembly ... now I wait to find a couple of components that I miss at an acceptable price.
from accounts better redone, for OT of 1350 ohm it has Pout 4.5w and Dout 9% ... not a great result ...
I tested it ... it sounds good and more than I expected but it produces a fixed rumble and I couldn't understand where it came from ... the packaging is too convulsive, i mean ... I should find a way to pack it in a wider chassis with the power supply furthest from the rest of the circuit.
