Apparently not, not even Joe after all these years of promising to measure the acoustic distortion, is there anything stopping you, you are the speaker guru here, and you have learnt something too, or just carry on with the blah blah blah, it is funnyAnyone want to independently do some measures?
Do you really not get it, or are you just "speculating" too?I don’t see Joe feeding us crap. He has said nothing inconsistent with what i know about all of this. He has done some interesting speculation, and he has been clear that much of what he has said is a thesis.
I have seen a lot of crap thrown his way, but i see little to practically support the arguments made against what Joe has to say.
Do you know the intended destination, or even the route? Seriously, it's impossible to get a straight answer out of Joe what with all the random "speculating"We are not a tag team. But i will admit that i encouraged him on this journey.
but infinity ohms into 1A, to a 6 ohm load is infinite volts
A good point. No chip amp can approximate this, but a high voltage parallel OTL (not a CF) could.
Ah, a road (route) What is the purpose of going down that road?Any increase in the series impedance flattens the current phase angle and gets you down that road.
In another parallel universe and audio paradigm where current amplifiers are every ones run of the mill gear while voltage amplifiers are as rare as CA in our world we will find yet another joedoespindoctor quantum entanglement peddling pseudo scientific manure how VA is superior to CA because the voltage signal measured looks, aheem... "distorted" with respect to the current signal including some other "unknown mysterious" artifacts proudly "discovered" by the omnipotence of audio himself, welcome to the university of joedoepedia.
ps. btw this thread, or at least part of it, should be moved to the lounge, there is nothing particularly specific about tubes since a whole pile of posts and as such it's in the wrong sub-forum, create a new thread over at the lounge called for instance "Joe's back EMF thread" so he can have his own sandbox.
The discussion can continue here Back-EMF and flat impedance if you like
hi David McBean - -thanks for the reply - FWIW used Rg=275 as that was specified as Zout for an amplifier in this thread.
With such high source Z I assume one has to be extra careful in their speaker designs.
The stuffing in a MLTL for Eminence's B102 suppresses the first impedance peak below tuning but the second peak looks to be a problem.
I don't worry about all the numbers/equations when hornresp has swept those and other cares away
Planet 10 - do you observe such peaky behavior in your vented designs when driven CC ? (CC drive should be a good tool in cases where it works to advantage)
Jeff Medwin's SE KT88 Loftin-White amp sans feedback has gotten good remarks for sound quality (Zout probably not really CC)
- Tubes / Valves
- Do tubes actually sound like anything?
