changing the value of coupling capacitor
Image:
There is little point in changing from 0.47µF to 0.56µF. Why do you want to do it?
Emphasis added.
Why? … because change itself is very often the driving goal of DIY audio folk. Change to see what effect there is (tho' that begs, “then why ask us first?”) if any. Then there is change to dog perfection, whatever perfection is defined to be. Silver foil separated by hemp oil soaked virgin bamboo fiber paper…
Another poster suggested (loosely quoting) “substituting 0.56 µF for the present 0.47 µF would almost imperceptibly extend the low-frequency response a bit, at most”.
Even that is likely an overstatement! If the preamp was “correctly designed” at the outset, the 0.47 µF coupling capacitor's low-cut knee is well below 20 Hz to begin with. Very probably around 5 Hz to 7 Hz. So … dropping that knee 100% × (1 - (0.47 ÷ 0.56)) = 16% of 5 to 10 Hz leading to 4.2 to 8.4 Hz … is deep in the inaudible subsonic range.
Lastly, working mathematically backward … if the 'test' is just to see what a change-of-value does, as opposed to replacing the cap entirely, then
CTOT = C₁ + C₂
0.56 µF = 0.47 µF + C₂
0.10 µF ≈ C₂​
So, all that is needed is to tack-solder a little high quality 0.10 µF cap to the existing one. Again… why ask us first?
Best of luck.
“just do it”, then see.
GoatGuy ✓
Reactions: Beacon70
Going by that partial schematic, it appears that changing that .47u cap would not change performance unless the following stage has a very, very low impedence. And even then, the difference would not be audible.
With high impedence tube circuits, I don't understand the reasoning for using such high capacitance values for coupling. It effects response speed in some cases by loading down signal/level changes, and having an amplifier with ability down to sub-sonic levels is deterimental to performance as well. Who really needs to listen/have soundwaves at 10 hz in their music anyway? It only causes woofer "flopping" and increases rumble and hum effects. And that makes what you hear as music sound crappy.
I don't like crappy sound, but that's just me I guess.
