cascode distortion Spectrum.
Old 18th January 2017, 04:10 AM   #1
mashaffer is offline mashaffer  United States
Default cascode distortion Spectrum.
I have been looking at the triode cascode circuit as a phono preamp first stage as many have done. I see the advantages as high gain, low input capacitance,and relatively low noise.
To get a feel for the circuit I like to run spice simulations which I did in this case. I simulated for circuits using 12AU7, 6N1P, and 12AX7 using various biasing schemes.The difference in gain was about 9dB with the 12AX7 giving the highest gain (expected higher Gm tubes to have given the higher gain).
I also looked at the FFT knowing of course that the results would be of limited accuracy. Interestingly the distortion spectrum was amazingly consistent regardless of which tube was used or the bias points. HD2 was very low -60 to -80dB but HD3 was always between -36dB and -39dB. I kind of expected HD3 to dominate but was surprised that it was that high and that consistent.
So three questions for those who have designed cascodes.
1. Is the HD3 really this high (or the relative differences between HD2 and HD3).
2. Are there any design considerations that can be used to minimize HD3?
3. How objectionable is the HD3 in real life.
mike
If you are not a part of the Solution... you are a part of the Precipitate
Old 18th January 2017, 05:46 AM   #2
artosalo is offline artosalo  Finland
artosalo's Avatar
...HD3 was always between -36dB and -39dB.
Seems too high distortion at signal levels present in phono input.
What signal level did you use in simulations ?
Old 18th January 2017, 09:41 AM   #3
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
Cascoded Triodes gives much better real-world performance than text-books suggest, and simulations are certainly not very reliable.
I started work on series cascodes over 12 years ago, and found that the important consideration is the cascode voltage. Using a triode at the top gives poor results compared to higher-gm devices, and bipolar transistors measure and sound the best.
Turning from Series to Shunt cascode improves performance again, and the gain can be increased greatly, without having to resort to high voltages.
It makes a superb RIAA EQ stage, because the output is a current, and so you only need a shunt-connected EQ network. this in turn means that the EQ performance does not get corrupted by the ra of the triode.
Here's an outline drawing of a 6Э5П shunt cascode, and a real measurement of spectrum at an output voltage of 1kHz, 75V peak-peak. No sign of 3rd harmonic problems at all!
The stage gain is about 170.
Old 18th January 2017, 09:45 AM   #4
работник
The consistency of the Harmonic series in the output can be seen by looking at the 145V peak to peak output:
Old 18th January 2017, 11:24 AM   #5
DF96 is offline DF96  England
Getting results which look wrong probably means they are wrong. Something in your circuit or analysis is not right. To a first approximation, a cascode gives you the distortion from a plain triode feeding into a lowish impedance so you mainly see the nonlinearity of transconductance. Second order should dominate.
Voltage gain is almost meaningless, as a cascode is a transconductance amplifier.
Old 18th January 2017, 11:52 AM   #6
работник
We are talking about the practical circuit: the load resistor is included. The outcome for an amplifier is a circuit delivering voltage gain.
Voltage gain is most relevant to the circuit performance, and the measured distortion also, at least somewhat.
Old 18th January 2017, 02:00 PM   #7
With a low value anode resistor R, voltage gain is gm times R. The fact that the OP did not see this means either that he used a higher resistor value, or a different one for each circuit.
With a perfect CCS load voltage gain will be around mu^2. This will require a CCS with impedance much higher than mu x anode impedance - say CCS impedance of 20-50M for a 12AX7?
Typical biasing might mean an anode resistor roughly equal to the anode impedance. This will give a voltage gain around mu. I suspect that this is roughly what he saw, but modified by the exact resistor value.
Old 18th January 2017, 02:48 PM   #8
5mV in output was around 300mV (Both peak).
mike
Old 18th January 2017, 02:51 PM   #9
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Why ever would you expect H3 to dominate in a single-ended triode circuit? Listen to DF96, he's never wrong.
Old 18th January 2017, 02:55 PM   #10
The basic circuit...
Attachment 592967
I did diddle with the load resistor some with the other tubes (esp with the 12AX7 as the current was so much lower).
The above circuit gave this result.
Attachment 592968
Attachment 592969
cascode distortion Spectrum.Hide this!Advertise here!
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
6C33C distortion spectrum estrano Tubes / Valves 1 22nd June 2010 03:39 PM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Copyright ©1999-2019 diyAudio
