The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 22nd July 2015, 08:58 PM   #641
slmnklyc is offline slmnklyc  Turkey
Hi
I have attraction dac and small amp which is 2 x 10 Watts of Power into 8 Ohm or 2 x 20 Watts into 4 Ohm.
Dac is 12v 200mA
Amp is 12v ???A
I want to build 2 psu for them by using Jan didden regs.
3A for amp will be definitely ok..
It is working with a 12vdc 1A cheap wall adapter now.
I don't know maybe it is not work with 1A Jan didden reg..
What is the max amper value while keeping the design mostly original?
I have no electronic knowledge!!
Can you tell me what are the exact material list to power my dac and amp?
Such a list like amb lab psu s.
I will buy the PCB boards with my next salary..
Help please?
Old 26th July 2015, 02:03 AM   #642
wendelltate is offline wendelltate  United States
Hi all,
I am building the 2.2 board to use with a B-3 preamp. I am having trouble locating the 6.8 Zener at .25w (if I am looking for the correct thing). Will this 5.6v at .25w work? The Mouser part number is 610-1N4626
Thanks for any help. I feel like such an idiot dealing with all of this...
Old 26th July 2015, 02:21 AM   #643
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Super Regulator
Try these Mouser part numbers
512-1N5235BTR
512-BZX79C6V8
78-1N5235B
78-TZX6V8B-TAP
771-BZX79-C6V8AMO
Old 26th July 2015, 03:07 AM   #644
Thanks!! What about the heatsinks?
Old 4th September 2015, 05:00 PM   #645
dodo is offline dodo  Poland
Originally Posted by jan.didden View Post
I send all files to Jason, I think he ordered the boards.
Jan
It is already 6 weeks passed and still lack off PCB in diyAudio Store.
My question is is there any chance to se those super regulator 2.3 ver boards in the store or I should forget about it ???
Old 5th September 2015, 08:32 PM   #646
Jason is offline Jason  Australia
diyAudio Administrator
Jason's Avatar
Super Regulator
The 2.3 boards arrived a while ago but somehow they didn't make it to the navigation system of the store....
Available now at: Super Regulator V2.3 - Power Supplies and Accessories - Circuit Boards
Old 8th September 2015, 01:13 PM   #647
Dirk1 is offline Dirk1  Germany
Hello there,
I need for my Dac only positive voltage, it is possible.
Input voltage ~ 17,00V output voltage 12,00V current ~ 450mA
Input voltage ~ 12,50V output voltage 5,00V current ~ 380mA
How do I calculate the resistors to the voltage to fit?
Thank you.
Hallo,
ich brauche für meinen Dac nur positive Spannung, ist das möglich.
Eingangsspannung ~ 17,00V Ausgangspannung 12,00V Strom ~ 450 mA
Eingangsspannung ~ 12,50V Ausgangspannung 5,00V Strom ~ 380mA
Wie berechne ich die Wiederstände um die Spannung an zu passen?
Danke
Old 8th September 2015, 01:42 PM   #648
R.I.P.
Originally Posted by Dirk1 View Post
Hello there,
Thank you.
Hallo,
Danke
Which circuit are you using?
Post a sch and then a Member can help you through the resistor selection process.
regards Andrew T.
Old 8th September 2015, 04:32 PM   #649
AntrewT thanks for your answer,
as there are several drawings, I have a link attached with the original drawings.
I want to use 4 of the DAC modules.
http://www.dddac.com/documents/dddac1794_nos_ver30.pdf
AndrewT danke für deine Antwort,
da es mehre Zeichnungen sind, habe ich einen link mit den Orginal Zeichnungen angehängt.
ich möchte 4 von den dac Modulen verwenden.
Old 9th September 2015, 12:57 PM   #650
R.I.P.
The DAC datasheet shows the existing PSUs.
Where is the new PSU that you propose to use?
regards Andrew T.
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
Copyright ©1999-2019 diyAudio
