Muses Volume
I'm just getting up to speed on this project. It looks great. I have two questions for starters.
Is there any way to add, say, 2 additional inputs? I had planned on a different input selection "product" and have already drilled out my chassis. 😡
Next, if I use V2 I understand there is no display. I didn't see anything on the mainboard but is there a way to indicate which input is being used? Like an LED indicator connection?
Thanks!
Bilder werde ich nächste Woche posten, auf der gekauften Relaisplatine für die Chinch-Eingänge ist anscheinend ein Relais defekt. Wenn ich alles fertig habe werde ich Bilder schicken.
Please post in English.
Translation:
I will post pictures next week. There seems to be a faulty relay on the relay board I bought for the RCA inputs. I will send pictures when I have everything ready.
  • Thank You
Reactions: Deenoo
Hello,
unfortunately it took a little longer with the pictures, I have a strong hiss at 7250 heart. After I shielded the cable from the IR sensor, the hissing disappeared.
When it's warmer I'll have to paint the front again.
