Compound loading 6th order quarterwave "Super Planar" horns and pipes concepts/builds
LORDSANSUI , hello! :) Thank You for sharing this again, very cool . .
Hello MMJ,
Long time no see you around, hope you doing well.
Do you mind to share with us the reason to add those array holes in the Paraflex top 1x12 top design ? What effect they brings to the Loundspeaker?
As you can see in the thread below, I'm trying to model this box in Hornresp and the results are promissing.
https://www.diyaudio.com/community/threads/hornresp-model-for-paraflex-top.403288/#post-7452873
  • PFX 1x12 top-150mm-FINAL.pdf
