Up quelqu’un aurait-il les photos ? Elles ne sont plus disponibles et je dois faire les manip
This is an English language forum. Please post in English or provide a translation.
Does someone have photos? The are no longer available and I need to do some work.
Changing voltages for the DD Series is a very easy thing if you have the correct information.
You just need to change jumpers in two (2) places - see attached files.
Have fun but be very careful since dangerous high-voltage is present.
Yes, but there are jumpers in the small power supply as well.
In addition, do not forget to change the fuse ratings accordingly.
hello and sorry for late reply. So what should i do with the JMP? Cut them?
@xavion: Have you been able to successfully do the change to 230 VAC? If yes, can you post the change to the 6V power supply and a complete description of what you did?
I have the same amplifier board that you have. The documentation further above in this thread unfortunately doesn't describe this type of power board that you and I have.
Thx
Ben
- Subwoofers
- Velodyne DD12 : change to 220V
