Velodyne DD12 : change to 220V
Changing voltages for the DD Series is a very easy thing if you have the correct information.
You just need to change jumpers in two (2) places - see attached files.
Have fun but be very careful since dangerous high-voltage is present.
  • Voltage Change -Velodyne DD1_1.pdf
  • Voltage Change -Velodyne DD1_2.pdf.pdf
  • Voltage Change -Velodyne DD1_3.pdf
Am I correct?
hello and sorry for late reply. So what should i do with the JMP? Cut them?
@xavion: Have you been able to successfully do the change to 230 VAC? If yes, can you post the change to the 6V power supply and a complete description of what you did?
I have the same amplifier board that you have. The documentation further above in this thread unfortunately doesn't describe this type of power board that you and I have.
Thx
Ben
