Hello
Could somebody give me the wiring of straps on the amplifier for a DD12 in 220v setting.
I have one in 110v setting, and I want to modify it in 220v for french voltage. I put some photos of the straps :
The Velodyne DD12 amplifier :
On the components side :
The straps, near the orange caps
This is the 110v cabling
Who could give me the 220v cabling...
Philippe
Philippe
hi Philippe
i think that why don't u ask on the amp forum. in this problem i think u change the transformer is better. input is 220 v and out put tab is 110 v.
bye🙂
bye🙂
No transformer here...The d class amplifier is directly powered by the 110v, after doubling, or by 220v without doubling.
Philippe
Philippe
Philippe i'm not sure for this. i did not learn about the amp for a long time. this sub amp i had interested before. Philippe if on here u don't get the answer. u may post on class d amp thread again. 😉
I can't see your pic very clearly. Some power supplies designed with a switch on board to let you select the voltage and some don't. So you may need to check the power supply to see if it supports this feature.
Voltage convert
Hi Philippe,
have you changed the voltage without any external transformer?
Greetings
Max
Hi Philippe,
Greetings
Max
Yes
It is a switched supply, directly on the 110/220 like a PC one
Then you have just to wire without the doubler.
It works fine now.
Philippe
It works fine now.
Philippe
Hi Philippe,
could you explain me how to transform a 110V DD amplifier in a 220V ?
Thank you !!
Max
Thank you !!
Max
Hello , I am also interested to know how you have done to make it work on 220 v. I wanted to send you an email but as i am a new member i can't.I'm french too so if we could continue this conversation with mails ^^ Thanks
You guys shoud really try the power supply forum :
http://www.diyaudio.com/forums/forumdisplay.php?s=&forumid=67
Or the Class-D forum :
http://www.diyaudio.com/forums/forumdisplay.php?forumid=49
You won't get much of a response here.
Good luck !
Good luck !
Hello,
Thanks for your answer .
Actually i found how to do this on the web and did it myself.Some jumpers to move, not so difficult.
changer velodyne dd en 220v
vous avez un schema ou des photos plus precises pour effectuer la convertion du modele 110V pour un usage 220 V ?
mon mail catteaut@wanadoo.fr
merci
thierry
merci
thierry
Re: changer velodyne dd en 220v
Salut kto59,
Si j'étais toi, je tenterais de contacter da1boss par email car il semble avoir réussi. Tu vas dans son profil et tu cliques sur "send email to da1boss".
Sinon, je te donne le même conseil que je lui ai donné. Vas reposer la question dans le forum "Class D" ou bien dans le forum "power supply". Pose aussi ta question en anglais si tu veux avoir des réponses.
Bonne chance ! 😉
kto59 said:vous avez un schema ou des photos plus precises pour effectuer la convertion du modele 110V pour un usage 220 V ?
merci
thierry
Salut kto59,
Bonne chance ! 😉
Bonjour
Je suis intéresse par le schéma de la modification pour effectuer la conversion du modèle 110V pour un usage 220 V. voila mon adresse tof70270@free.fr merci
Good morning
I am interest by the schema of modification to perform the conversion of the model 110V for an usage 220 V. veils my address tof70270@free.fr thank you
Good morning
- Subwoofers
- Velodyne DD12 : change to 220V
