I used the Laterals on my original board design found here.
http://www.diyaudio.com/forums/solid-state/99739-symasym-5-3-aak-model-builders-thread.html
I've been listening to them with Laterals for over two years and perfer the sound.
But I see what you may be getting at. It could sound different with the new design. I let what have working break in some than I'll try the Laterals. It's an easy change.
Al
Al
Joined 2009
Hi Piersma,
I simulated your circuit, it doesn't work well. Unfortunately I don't have the time at the moment to analyze the amp circuit design to see whether there's a simple way to achieve rail-tail-rail without degrading performance. If you come up with something else I'd be happy to take a look at it and run through the simulator.
MikeB's and Roender's circuit design that I've implemented on my new PCB has far exceeded my expectations. I think it would best to leave the way it is.
Al
Al
- Symasym - Roender Style
