The Germanium-only circlotrons. Powerful, wideband.
I report for almost a year's work. Labor is collective.
Series of amplifiers Cyclothers of different configurations. In order to fully utilize the elemental base of germanium semiconductors.
The power band was able to extend from 30-50 to 600 kHz.
Power up to 36 watts. Maybe more.
Amplifiers are very stable.
Stable resting current. Stable output voltage, zero.
Two of the four diodes (VD1-4) are temperature sensors. Placed on radiators
Meander at 100 kHz.
Sounds like one hand clapping...
The best sound option is currently.
Feature of germanium transistors - increase of gain with increasing current.
On the graph, the dependence of the "beta" indicator on current. For 1T910AD
This also applies to other transistors of the circuit.
The previous version of the scheme, more simple. 1kHz, 10kHz, 20kHz.
Sinus: 0dB - 70kHz, -3db - 180kHz.
Well i know the next project I have been looking for something like this for years !
Do you think i will work well with silicon output devices ? I would like to know the standing current I assume this is a class A device
Regards Trev
