JLH 10 Watt class A amplifier
Old 24th September 2019, 12:13 AM   #5591
grunf is offline grunf  Croatia
grunf's Avatar
A few days ago I put the CRCRC filter back in power supply before the regulators, I lost another 2V on it and 3V on the regulator so now I have +/- 19V to power the JLH69.
The JLH69 sounds better again, so this combination definitely stays in the amp.
Old 27th September 2019, 04:18 PM   #5592
Cerniu is offline Cerniu  Lithuania
I see you have output transistors on separate heatsinks. Are they connected in some way that is not visible in the photo, or is it not a problem if they are on separate unconnected heatsinks?
Old 30th September 2019, 07:40 PM   #5593
grunf's Avatar
It doesn't matter because both transistors have the same dissipation, so they heat equally.
Old 13th October 2019, 10:11 AM   #5594
Mooly's Avatar
Duffo adele, your post has not been approved as you have been repeatedly told to post in English.
From the rules:
Not allowed
6: Posting in a language other than English without a translation.
Old 14th October 2019, 11:14 AM   #5595
Duffo adele is online now Duffo adele
hello to all I am french and the translations being very bad, my knowledge in very limited electronics I do not understand all.Est what one of you could give me the schema leads jlh2003 with the list of components and the rule of the current of rest for a power supply of + - 30 vd advance a big thank you to you
Old 14th October 2019, 03:14 PM   #5596
Hello to all i am french the traductions being very bab, but knowledge in very limited electronics i have a lot of trouble understanding you. Is that one of toi cloud give me the définitive schema of jlh 2003 with the list of the components and setting the quiescent current for a + -30v Feed in advance a big thank you to you
Old 14th October 2019, 03:57 PM   #5597
prasi is offline prasi  India
prasi's Avatar
Hello Adele,
Have a read at the site here...
The Class-A Amplifier Site
Also I have posted PCB design for 2 pair output device 2003 version.
Please see here...
My revamped site https://sites.google.com/site/analogdesign1234/
Old 17th October 2019, 11:51 AM   #5598
Français
Anglais
Hello message to huggygoud I already explained on the forum that I don't understand anything about translations.is what we could match by email or phone. I want to assemble a jlh2003 and I have a great need for advice. But in good French. Thank you
Dictionnaire Français - Anglais
Bonjour message destiné à hugg
bonjourintj
bonjournom, m (pl:bonjours)
message/me.saʒ/nom, m (pl:messages)
destiner/dɛs.ti.ne/verbe (destine/destinait/destiné)
se destiner/dɛs.ti.ne/verbe (destine/destinait/destiné)
destinéadj
àprep
à l'initiativeprep
à l'inverseprep
à l'issueprep
à l'époqueprep
à partprep
à traversprep
Traduction automatique 5
Model: Generic (by SYSTRAN) - (profil utilisé)
Model: Legal (by Crosslang)
Hello message to huggygoud I explained on the forum that I don't understand anything about translations.is what we could match by email or phone.
Model: Dialog (by SYSTRAN)
Model: Legal (by SYSTRAN)
Hello message to huggygoud I already explained on the forum that I don't understand translations. is what we could match by email or phone.
Model: IT (by SYSTRAN)
Hi message to huggygoud I already explained on the forum that I don't understand any translations.is what we could match by email or phone.
By systrangroup.com
With openNMT
On ovhCloud
SYSTRAN ©2019 All rights reservedAccord de licence
HAUT DE LA PAGE
En utilisant ce site, vous acceptez que des cookies soient utilisés à des fins d'analyse du trafic et pour mémoriser vos paramètres sur ce navigateur et cet appareil.En savoir plusX
Old 18th October 2019, 07:02 AM   #5599
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Originally Posted by tschrama View Post
Thanks every one... I know the 2n3055 are old and considered not suiteble for quality audio.. I also read that in D.Self's book.. so I would like to switch to the MJ15003's.. I just need to find them first
greetings,
Thijs
I use the MJ15003/4 in an update of the 1980's Maplin disco amplifier.
They work very well.
I get mine from CPC, Farnell and RS Components with no problems.
PCBCAD51 and PCBCAD360 out now >>> https://www.murtonpikesystems.co.uk
Old 28th October 2019, 12:26 PM   #5600
Rallyfinnen is offline Rallyfinnen  Sweden
Hello!
Looking for advice/suggestions on JLH projects here.. I bought a pair of the chinese JLH kits (white PCB 1pc JLH 1969 Class A Verstarker Board Hifi hochwertiger PCB mot/2n3055 Do it yourself Kits | eBay)
and a pair of 'JLH2003' boards with dual supply and double outputs 2 PCs Hood jlh2003 Class A Single-Ended Power Amplifier PCB 2 Kanal 22w+22w | eBay
The white boards I have been thinking of modifying to 'sublimed' ( sublimed JLH1969 )
Or, should I just keep it as is, or maybe replace just outputs?
The dual supply/dual output boards need populating.. any recommendations on what good and easy to find transistors I should use? Possible improvements?
JLH 10 Watt class A amplifierHide this!Advertise here!
20 Watt Class A amplifier JOE DIRT® Solid State 8 1st February 2012 12:41 AM
JLH 10 Watt class A amplifier DomKo Solid State 3 18th November 2003 07:32 AM
Copyright ©1999-2019 diyAudio
