Thank you, that worked.Also note that the typical SPL range in Holm is always less than 0 dB. In XSim the typical range is something like 60 to 120 dB. So you certainly won't see anything in XSim. When I used Holm I'd add a 99 dB offset (the maximum allowed) before exporting the file.
I have a new audio interface (Audient iD24), where the optical outputs I want to send audio to for measurements are ASIO channels 9 and 10. I love Holm Impulse but it only supports the 4 first ASIO inputs/outputs and I really need to use 9-10 out. Optical in is 3-4 so it's no problem. Do you guys/gals know of a workaround that can have Holm send output to ASIO out 9-10?
You can also get it from there, including the runtimes: https://rephase.org/dl/Holm/Hello.
Thanks for the program. I've been using it for a few years.
Now I have formatted my computer and I don't know where I can download it?
is it possible to get it?
Thank you
- Design & Build
- Software Tools
- HOLMImpulse: Measuring Frequency & Impulse Response
