How universal is this remark? I use such a ‘filter’ in my 2SK182 after the Meanwell. It sound good.Salas what a lot of low & mid information lost with SMPS.
This info is related for comparison between a SMPS + Mark Johnson PO89ZB SMPS DC inline DC vs L-Adapter and in my audio system.How universal is this remark? I use such a ‘filter’ in my 2SK182 after the Meanwell. It sound good.
The noise seems like when you phone and it's busy this kind of noise is only playing music, without music hiss like white noise.
Both kind of noises it's only in right channel like with the SMPS.
When upsampling to DSD it's more strong so surely laptop polluting the sound.
Salas SMPS + filter 0 noise playing natives DSD files also 0 noise upsampling PCM files to DSD256 I guess both thanks to the DC filter installed between de noDac PSU & BiB, now two DC filters: one for the SMPS & the other PSU-BiB. So I'm sure the noise is L-Adapter related.
Maybe the laptop prefers floating because its normally a battery operated device. When on SMPS recharging mode we don't know if the DC output is referred to mains either. In general try NTC thermistor for mains earth to chassis and/or the L-A's DC out zero should be tied to its chassis.
Could be better to connect 1st mains cap negative to chassis?Maybe the laptop prefers floating because its normally a battery operated device. When on SMPS recharging mode we don't know if the DC output is referred to mains either. In general try NTC thermistor for mains earth to chassis and/or the L-A's DC out zero should be tied to its chassis.
- Power Supplies
- L-Adapter
